Not sure I want to go into a lot but detail but to be safe the Hi-port will have a more reliable valvetrain and has the best I/E ratio. I'm sure all three heads would have a ton of power potential.
I'm actually looking for a pair of heads for my turbo car...So if you cant go into detail, who would you recommend that would?
If you're considering using one of these three heads for your build, the Hi-port will be your best choice for your build. I doubt any of these three examples have been set-up for a power adder application.
I agree... Hi-ports will be your best option... PP's are expensive to build and tigers are not that power adder friendly.....from my personal experience..
What makes the hi port the better choice? Do all three have comparable deck thickness? Material thickness in the valve train area?
The Following User Says Thank You to opeliac For This Useful Post: | ||
.4- 291 .5- 344 .6- 385 .7- 409 .8- 414 .8- through the Northwind intake 398 .85- 414 .9- 408 We are planning on .800 lift SR 50MM cam, and about 480 CI, IAII-A Block. I went with the Northwind to run it under a flat hood on a 74 T/A with a shaker scoop. The plan is to bust some unsuspecting chebby butt at the local drag strip, or anywhere I take it.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
I hope he wasn't going for max port..... I'm a fan of Dave as he has made big power for me for 20 years.... he took my 406 from 12.20's to 11.20's for $800 in 97.. then to 10's at 3150 lbs with a hyd. Roller.. If he went for max power, 414 isn't there.... ?? Then 6.40's with a shoe string budget... Last edited by Scott Roberts; 01-07-2020 at 11:20 PM. |
The pro ports arent available anymore so those are eliminated, the Tiger heads are nice but cost more and in a turbo build i doubt they're worth the added expense. The HP heads are by far the cheaper option and paired with a turbo will make HUGE power.
Thanks, Stan
I got to say that for a high heat Exh motor like a turbo set up I would want a Exh port lay out like a RAV head and such.
X 2 |
Nice!! What's the Minimum CSA in the Head?
About "yeah" big 🤣🤣🤣
All I'll say is min csa is at valves
Told ya! |
#38
Brian,
That is interesting. I have never worked on a head where the throat was not smaller than the valve. Stan
#39
Sorry it is the throat, didn't think people would take the "at the valves" literally lol
#40
Thread Tools | |
Display Modes | |
