#81
A member here pm'd me and said bes has a cnc program them. I'll try to reach out to them at some point and learn more about it.
#82
That is surprising....that head had such a limited use... sorry I spoke so soon... it was an assumption on my end..
#83
I would be surprised if tony has a program. Usually on max effort heads, he does 4 ports and copies them and runs the program in the other 12. The problem we had with the wenzler junk back in the day was the core shift in the castings were all over the place.
#84
Heads with core shift would require hand porting wouldnt it....no 2 ports being the same.... hard to cnc that I would assume..
#85
Hah! That's nothing I was called a Buick guy ��
#86
Correct
#87
#88
Nothing....someone (in the know) told me that and I was forwarding the information.
BUICK'sTTF!!! |
#89
That must mean you hate Pontiac's.... how could you build a pontiac.... |
#90
But I only did the heads and intake manifold. |
#91
Indication moron....
#92
Are you threatening me with posting info "well within the rules" ? Who around here does that ? Yes, its creepy and morally wrong. Now, are you so butt hurt over me asking if you like Pontiacs ? Did not know you took it so hard. Was it that big a deal to you ? |
#93
I said they had core shift. They look like they were cast in someones garage.
#94
About all the cr@p. See, I love Pontiac,s and only Pontiac,s. I have taken a great deal of interest in max Pontiac power since high school. What is max pump gas power, max race gas power and on. So I went about finding exactly what was the deal. Befriended Dan Whittmore and learned a ton. Back then max pump gas power was 550HP. Max race gas power was 650-700 HP but Chevies could get 850 HP. Dan knew "everyone". Pontiac engineers, Smokey U, Fulper, Maxey and was best buddies with Jim Butler. So I got a lot of insight on all the players from that era. Jim B used to talk to me for a couple of hours just because of his friendship with Dan. I learned a lot, so I have opinions like everyone else. And that is what this place is supposed to be about, opinions, learning and helping each other with a common interest, Pontiacs. Some around here, big players treat me and the rest with respect and don,t come at me with the idea that just because I have not actually made 1200NA HP I have no place even having a idea or opinion on the subject. Langer is great about that, Boss Bird guys and others too. Mike thought enough to reach out to me and introduce me to Scott Brown and not sit back and talk down to me. Its one of the reasons I thought so much of him. And there are others, the 'check writers" who have made big big power but could not do it themselves to save their life. They just have money and do not think twice about belittling someone when they barely understand how a engine and trans really work. And I do not think you are one of those guys. You are a tech and know what you are doing. I have a GREAT deal of interest in max power Pontiac,s. Have put a lot of thought into it and yes, talked to a lot of very smart people on the subject. A super smart person confident enough to share hard won info is worth their weight in gold to me. The 461 going together right now should have been done before 2010, the build started in the early 2000s. The local economy took a big hit around 2006 and so did that build. But I still have raced the old engine the whole time because that is what I do. It should be one of the best, most powerful 461 pump gas Pontiac's done. So, I race, build engines and have opinions and ask for others opinions. Its what this place is all about. Just don;t be one of those guys who tries to squash opinions that are just as valid as anyone else. Me and you are all good, no problems here. And I took note of what you said, hear your point. No need for that stuff. |
#95
Checkwriterttfmf!!
#96
You know us computer racers talk to each other. But I will not post on what I heard through the grape vine.
Here are a few quotes from some web site Quote:
#97
Way back in post#40 Mike G gave a phone#. Anybody tried it?
#98
If the head being CNC'ed has core shift vs the head used to map the program, how can that be adjusted ? Unless you have cray vision and can see the core shift prior to milling? How can you adjust for that.... again, all of those axis are absolutes. And please post your supere secret info shared amongst your nerd friends... |
#99
Maybe I'm wrong but if the as cast port size is small (which the sc intake ports are somewhat small) and the cnc program has decent size to it then core shift shouldn't matter, should it? I guess there is a possibility that you break through into water but the sc head is a pretty meaty head and i see that as unlikely. But if it did weld it up and go racing.
#100
Maybe if I make it bigger you can read it, Or is it that you just know it all. Quote:
