Old 01-18-2020, 12:31 AM
rod cole rod cole is offline
Default holley regulator bypass
i have put a .060 hole on the other side outlet on a holley carb deadhead type regulator . Running a tbi in.tank pump do you feel .060 is enough to keep pump happy or too much hole to make the 6 psi for carb. Read about it with a zz3 conversion GM made for 3 gen f-body couldnt find size of hole. Thanks Rod
Thread Tools
Display Modes
