Old 04-13-2020, 03:50 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
Originally Posted by TAKerry View Post
73 lemans, yours look a bit too narrow also for my liking. Im sure they work great for you but if I were to build some I def. would have a wider footprint. I am nowhere near a structural engineer but I have built and torn down enough stuff in 40+ yrs of construction to know what works and what doesn't.
I hear ya. The fronts are pretty narrow. Its a small tire for sure. Wouldn't work with the 245 road tires I run with.
Originally Posted by Bluesugar View Post
73LeMans, what is your procedure and how do you lift your car on and off those
" grand " stands like that?....looks very impressive!!
I get the car up level on some tall jacks stands under front frame and rear axle. I do this in two passes, as the tall stands are 22.5" high rather than the 16" of the stubby stands. Then I raise the car by the front cross member with a 3 ton floor jack and a 4x4. In back, a 2 ton bottle jack sitting on a 6x6. I do each end of the car very slowly all the while placing wood under the stands to make sure they are never too far away to catch the car if anything happens. 2 stands are always in contact with the car as I go through the process. I start with the front and then the back. I do this until there is enough room to slide the cribs in.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
Old 04-13-2020, 07:37 PM
73LeMans's Avatar
lol...grand stands. I just got that.
Mark S
>>My 73 Build thread
