A body rear spring help. #167 spring rate?
Looking to replace rear springs in a '71 that sits a little high out back. The ride seems good with a variable rate spring rated at #158.
My choices are : A constant rate spring @ #122 which seems a little soft (on paper) A Variable rate rated at #167 which might be a little harsh? The #167 is not much more that #158, maybe I couldn't tell the diff but I am not looking for a buck board. This is GMC Sprint which is normally empty in back. Any thoughts?
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
Are the current springs old and worn out? Are you opposed to cutting them to achieve the ride height you want? I like the ride in mine with convertible springs cut to the desired height.
'65 Tempest 467 3650# 11.30@120.31 |
Looking to replace newer rear springs. Wish I could cut a double pigtail spring!
The bottom has a locator on yours? Mine only locates at the top...
Removed the Moog CC507s & installed Moog 5413s. Spring rate is #167.
Time to put some miles on & see. Car sits level, maybe the caster has improved?
