Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 02-22-2023, 10:21 PM
bankbook's Avatar
bankbook bankbook is offline
Default Garage clean out so parts up for sale part 1
Organized the garage and am selling the following items. Most are 79 Trans Am
• ShoGun Industries Kool-Kan Fluid heat exchanger KK12209 New. $150.00
• MSD 8563 ProBillet distributor-USED sent to MSD for inspection, Base has cut for wire pass through, sealed no issue with performance. Has HEI adaper cap. $250.00
• Flame Thrower HEI cap with coil and rotor (Tune up kit) minus weights and module was used -New except for module. $ 80.00
• Trans am brackets-Alternator (499749), double Crank pulley with single AC, rear PS pump bracket only. Powder coated semi-gloss black. $200.00
• PYPES Trans Am Chrome exhaust splitters 3 INCH-new. $100.00
• QAL Front coil over springs 79 Trans Am 350 lb. Mock up only 65.00
• WFO 1.5-inch 4150 Drop base New in box with filter. $200
• Dominator 2 inch drop base plate only (doughnut) New. $150.00
• Cold Case Radiator GPF18 brand new in box. $325.00
• 1974 Quadrajet #17057253APW 0497(400 4speed?) clean, needs rebuild $75.00
• Olds (?) Quadrajet 7044263MM 3183 clean, needs rebuild 75.00
• Smith Bros push rods 5/16 (8)9.30, (8)9.50 Break in time only, clean. $65.00
• Smith Bros push rods 3/8 (7) 9.90, (7)9.550. Break in time only, clean. $65.00
• Smith Bros push rods 5/16 116 wall (8) 9.75, (8) 10.00. Break in time only $75.00
• Comp Cams Magnum#7263 5/16 pushrods. (8) 9.30. Break in time only $65.00
• Holley 36-181 Jet assortment kit, mostly complete with removal tool. $50.00
• (2) clean HP950 fuel bowl take offs. 35.00
• MSD 8969 RPM activated switch. Believe new in box. $135.00
• Richmond 5 speed Super Street Transmission New in box. $3300.00
• (8) BRC pistons 4.450 bore for CV-1 heads. 2 have slight damage from valve kiss. Will not affect performance. Low run time $250.00
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 02-22-2023, 10:30 PM
alex s's Avatar
alex s alex s is offline
pm sent
Old 02-22-2023, 10:53 PM
bankbook's Avatar
Originally Posted by alex s View Post
pm sent
Replied.
DOC'S TA
Both 4 speeds!
Old 02-23-2023, 05:00 AM
Drag Star Le Mans's Avatar
PM sent
DragStarLeMans
Old 02-23-2023, 06:30 AM
mysticmissle's Avatar
Doc
If the flame
Thrower stuff is available could you post a pic, is the module used and back or used and not with the kit? and shipping to 02822
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 02-23-2023, 12:21 PM
bankbook's Avatar
Originally Posted by mysticmissle View Post
Doc
If the flame
It is all there. If I remember correctly Installed it to see if there was problem with other distributor, but there was not.
Having issue with pics today. Send me a pm with number to text to.
Shipping $28.55 UPS
DOC'S TA
Both 4 speeds!
Old 02-27-2023, 05:06 PM
bankbook's Avatar
UPDATED.
• MSD 8563 Pro-Billet distributor-USED sent to MSD for inspection, Base has cut for wire pass through, sealed no issue with performance. Has HEI adaper cap. $250.00
• Flame Thrower HEI cap with coil and rotor (Tune up kit) minus weights, -New except for module(used for startup). $ 80.00
• Trans am ENGINE accessory bracket kit-Alternator (499749), double Crank pulley with single AC, rear PS pump bracket only. Powder coated semi-gloss black. $200.00
• QAL Front coil over springs 79 Trans Am 350 lb. Mock-up only 65.00
• Smith Bros push rods 5/16 (8)9.50 Break in time only, clean. $65.00*PENDING*
• Comp Cams Magnum#7263 5/16 pushrods. (8) 9.30. Break in time only $65.00*PENDING*
DOC'S TA
Both 4 speeds!
Old 02-28-2023, 05:13 PM
Tom Vaught's Avatar
Boost Engineer
What are the gear ratios for this transmission?
Richmond built some 5 speeds with a 5th gear was a "Overdrive" ratio.
Tom V.
Old 02-28-2023, 08:24 PM
bankbook's Avatar
Tom V.
Sorry, part number is 7020526B
First Gear Ratio:
2.89:1
Second Gear Ratio:
1.85:1
Third Gear Ratio:
1.31:1
Fourth Gear Ratio:
1.00:1
Fifth Gear Ratio:
0.77:1
DOC'S TA
Both 4 speeds!
