Old 02-07-2024, 04:16 AM
Transamric's Avatar
Default New Trunk Weatherstrip Install
But before I install the new, I have to safely remove the old W/S. The paint is nice so can't use any chemicals too strong. Any recommendations as to what methodology has worked well for you guys?
Old 02-07-2024, 07:58 AM
grd777 grd777 is offline
Try Goo off
Old 02-07-2024, 08:24 AM
Norwood's Avatar
Norwood Norwood is offline
Use a heat gun from the underside
Old 02-07-2024, 10:20 AM
78w72 78w72 is offline
3M makes a product specifically for this, doesnt harm paint & will soften up the old glue so you can wipe it off with a rag or usually a little more effort with a old toothbrush or nylon brush. Should be able to just pull off the old W/S or try heat from underside but be careful, too much heat will damage the paint.
I have some of the 3M left and can get the part# if needed.
Old 02-07-2024, 09:13 PM
hiyabradHO hiyabradHO is offline
Would love to get the part number. Thanks.
Old 02-08-2024, 02:26 AM
Formulabruce's Avatar
Please , please, Verify the Shape ( cross section) is the exact same, and same size. There are a ton of not so good repops, including late 80's GM stuff.
Old 02-08-2024, 06:30 AM
Red80TA Red80TA is offline
And make sure it installs the correct way, don't trust what just came out as being correct.
Old 02-08-2024, 11:57 AM
The can I have is 3m general purpose adhesive cleaner #08987. That # might be older, the current stuff I see online is part# 08984, probably have it in smaller cans at local auto stores or auto paint suppliers.
Follow instructions on the can & it works great & should not damage the paint, Ive used it on numerous trunk weatherstrips as well as T top channels.
Old 02-08-2024, 03:27 PM
sixty8ragtop's Avatar
sixty8ragtop sixty8ragtop is offline
Wondering what the factory spec was for the location of the trunk weatherstrip seam (where the ends meet)? My seam is located at a 2 o’clock position, which so far has avoided moisture accumulation at the typical 6 o’clock location. Anyone have a picture of an original seal installation for reference?
1965 2+2 Convertible 421 HO 4-spd 3x2 8 Lugs
1968 GTO Convertible 400 AC Bench Seat Column Shift - Sold
Old 02-08-2024, 03:31 PM
Transamric's Avatar
I'm finding that out. I currently have 3 potential replacements; 2 different brand repros and 1 NOS I bought either in the late '80's or early '90's, GM #9825829 (box dated 1982?). The only one I can tell for sure is a latex covered one is the GM item. But it's considerably larger in every dimension.
I was able to cut some clean cross sections from my old molding and only the Ames FK201C matches pretty closely, but is a simple extrusion, not coated and noticeably less soft.
Any more ideas on finding a more accurate product?
Old 02-08-2024, 03:39 PM
For 2nd gen firebirds I recall reading the seam was a couple inches to the left or right of the trunk latch. thats where I put it on a few cars with no leaks.
If not doing a NOS type resto, Ive had very good results with the Metro brand trunk seal, door seals too, looks & fits nice & has held up for almost 15 years & counting.
Old 02-08-2024, 03:41 PM
Transamric's Avatar
Wondering what the factory spec was for the location of the trunk weatherstrip seam (where the ends meet)? My seam is located at a 2 o’clock position, which so far has avoided moisture. Anyone have a picture of an original seal installation for reference?
My experience is primary with 'F' and 'A' bodies, so may be different for your app. However in every case the end seams have been near the 6 o'clock position. And by 'near' I mean usually a bit to the left of center.
The Following User Says Thank You to Transamric For This Useful Post:
Old 02-08-2024, 05:07 PM
It appears that my 2 o’clock seam location may be a bit high. I have noticed that most replacement trunk seal seams are located at the 6 o’clock position. I have seen some very nice rides with a few inch offset in either direction from 6 o’clock. I have the flexibility to move or replace my trunk seal at any time, as I did not glue it in place during my last restoration. I have not experienced any water leaks so far, so my only concern is shrinkage over time. I am not the least bit concerned with any points judging repercussions..
Old 02-08-2024, 09:01 PM
As mentioned, original join location was just offset to side of latch.
Old 02-09-2024, 01:36 PM
unruhjonny's Avatar
I am subscribing to this thread from this post...
1970 Formula 400
Old 02-09-2024, 08:08 PM
In terms of removal, it's been a decade - or almost four - since I did mine on my '63, but I used 900 PreKleano (RM wax & grease remover). Over the years, I found that it worked better than Ditzler's or DuPont's stuff. It didn't melt what was left of the original weatherstrip, didn't hurt the paint (okay, I had to re-wax, but hey...), and did a nice job of releasing the adhesive. ISTR that I used a plastic filler spreader to work the thing loose.
The other advantage to this method is that assuming you have no paint work to do in or around the groove, you should end up with a surface which is well prepped for new adhesive. Mine has held for 38 years so far.
Oh, and I'd have to look, but I think I laid the seam at about an inch off 6 o'clock.
GL HTH
Lewis
Lewis Rosenthal
'63 Bonneville Convertible
'56 Safari
'82 Firebird SE
Old 02-09-2024, 09:40 PM
>>>> VIDEO BELOW <<<>>>Ames stopped selling the "skinned" with latex many years ago due to their being fragile.
One day a friend, who has a couple Formulas, and I took at look at cross sections and installs ( dry)
between us we had 4 seals to try.. one was late 80's generic .
The ONLY seal we found that has the correct profile, and is SAME dimensions , is the one sold by 1 a auto.
This video shows the part number AND he installs it in his own Pontiac.
This seal passed the dollar bill test, and doesn't make the trunk too tight to shut easily.
https://www.youtube.com/watch?v=ikBDF4xRdw8
The Following 2 Users Say Thank You to Formulabruce For This Useful Post:
Old 02-09-2024, 11:44 PM
Transamric's Avatar
Then I could always splurge on this one!! No doubt it's correct.
https://www.ebay.com/itm/176220573076
Old 02-10-2024, 10:22 PM
Hey rick, I have some NOS if you’re looking for that
The Following User Says Thank You to Tellyshavilli For This Useful Post:
Old 02-12-2024, 04:32 PM
Transamric's Avatar
PM sent. Tell me more.
