OHC-6 TECH Over Head Cam projects, questions and advice.
Old 03-13-2022, 07:15 AM
Jeff Hamlin's Avatar
Default PROJECT AVS-2
I've been creeping along on a project engine and one of the things that became evident was carburation would have to be something modern,
as OE carbs for 1966 sprints are nonexistent. So enter Edelbrocks 2VS 4bbl.
This was chosen mainly due to the number of Cammers already using them.
Yes, there are other options but after much consideration, I figured I too would go this route.
So I set up my Manifold on a mockup stand and have started working out the details to get it functional without overthinking this setup.
The first thing to address is butterfly clearance, clearly dealing with a completely different butterfly arrangement.
So I picked up a readily available spacer. .5" seems to be the norm.
Name:	ED AVS 1B.jpg
ID:	586136   Click image for larger version
Name:	ED AVS 1A.jpg
ID:	586137   Click image for larger version
Name:	ED AVS 1C.jpg
ID:	586138   Click image for larger version
Name:	ED AVS 1E.jpg
ID:	586139   Click image for larger version
Name:	ED AVS 1D.jpg
Old 03-13-2022, 07:19 AM
Default SPACER
After setting up this spacer I wasn't really liking the BULK so starting looking into bringing it down some.
You can see how much space there is from fully open to the manifold surface so I was thinking 3/4-3/8" might be worth a look.
Name:	ED AVS 1F.jpg
ID:	586141   Click image for larger version
Name:	ED AVS 1G.jpg
ID:	586142   Click image for larger version
Name:	ED AVS 1H.jpg
ID:	586143   Click image for larger version
Name:	ED AVS 1I.jpg
ID:	586144   Click image for larger version
Name:	ED AVS 1J.jpg
Old 03-13-2022, 07:24 AM
Default SPACER 2.0
I decided to dissect a few gaskets to see how much or how little spacing I needed.
After a few layouts, it looks like 3/8" would be enough. So now to locate or make one.
Name:	ED AVS 1P.jpg
ID:	586146   Click image for larger version
Name:	ED AVS 1R.jpg
ID:	586147   Click image for larger version
Name:	ED AVS 1S.jpg
ID:	586148   Click image for larger version
Name:	ED AVS 1T.jpg
ID:	586149   Click image for larger version
Name:	ED AVS 1Q.jpg
Old 03-13-2022, 07:35 AM
Default SPACER 2.1
While fitting things together the one thing that I'm wondering about is the balance of air/fuel going with this setup.
I was considering trimming out the stock manifold to address the butterfly clearance required.
However, after looking at the area on the manifold that would need to be removed I decided this is not a good option.
Quite some difference between OE Q-Jet to this AVS.
So maintaining any butterfly separation such as stock is out of the equation and I'm not fully sure how this will affect performance.
Clearly, the manifold is not fully divided within chambers but still on my mind, so much for not overthinking
I've posed this question to our group but have not heard back on anything from those using this carb.
I was able to find a 3/8" space and have it coming so I will remain on this course and will tackle linkages next.
Name:	ED AVS 1K.jpg
ID:	586151   Click image for larger version
Name:	ED AVS 1L.jpg
ID:	586152   Click image for larger version
Name:	ED AVS 1M.jpg
ID:	586153   Click image for larger version
Name:	ED AVS 1N.jpg
ID:	586154   Click image for larger version
Name:	ED AVS 1O.jpg
Old 03-13-2022, 12:26 PM
george kujanski's Avatar
When I had my Sprint I put a Holley spread bore on it (# 4165 comes to mind). I had to shave down one of the cam cover bolt heads because a piece of the secondary float bowl was leaning on top of it. Don't know if these still exist. I did a number of silly things back in the day.
george
Old 03-13-2022, 02:08 PM
Hokie1984 Hokie1984 is offline
Jeff curious what 3/8 spacer you found. I was only able to find something that was almost twice that thickness.
Old 03-13-2022, 06:38 PM
Default SPACER REQUIREMENTS
I found a no-name brand online and decided to give it shot.
However, I also found out the answer to my open spacer concerns.
I was on the Ed website and within the FAQ section was the reason I suspected.
And make it was within the book that came with the carb and I read right over it
So I'm now back to getting the 2696 required spacer which comes in at just over 3/4"
I may take it over to my machine shop friends and see what they think about milling it down some? We'll see.
Name:	3-8th SPACER.jpg
ID:	586225   Click image for larger version
Name:	SPACER REQUIREMENTS.jpg
ID:	586226   Click image for larger version
Name:	SPACER REQUIREMENTS 2.jpg
ID:	586227   Click image for larger version
Old 03-13-2022, 06:44 PM
Default LINKAGE
On the positive side, I was able to mock up a fairly simple and maintain a close to the stock location for the linkage.
Using both factory and aftermarket pieces it looks like I'll be able to maintain the stock cable and achieve the full travel needed.
ID:	586229   Click image for larger version
Name:	ED AVS 1X.jpg
ID:	586230   Click image for larger version
Name:	ED AVS 2 LINK 2A.jpg
ID:	586231   Click image for larger version
Name:	ED AVS 2 LINK 2B.jpg
ID:	586232   Click image for larger version
Name:	ED AVS 2 LINK 2C.jpg
Old 03-13-2022, 06:48 PM
694.1 694.1 is offline
Sounds like quite the taffy pull. Should I scrape up a Sprint carb for ya?
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 03-13-2022, 06:59 PM
Default FUEL & CHOKE
I swapped the fuel inlet so I don't have to add any wrap-around metal line.
This keeps the fuel connection close to the factory metal line at the rear of the engine and may even shorten the amount of rubber line used from the factory as well.
And it looks like the carb choke linkage drops right above the factory choke location so I should be able to incorporate it as well.
Name:	ED AVS 1C.jpg
ID:	586240   Click image for larger version
Name:	ED AVS 1S.jpg
ID:	586241   Click image for larger version
Name:	ED AVS 1Sa.jpg
ID:	586242   Click image for larger version
Name:	ED AVS 1Sb.jpg
ID:	586243   Click image for larger version
Name:	ED AVS 2 LINK 2D.jpg
Old 03-13-2022, 07:04 PM
No, I have carbs but that's the problem they have been scraped up for years and years, and IMO not worth the average $300 to "Rebuild" them anymore.
I just wanted to try something different with this build but wasn't looking to go full tilt such as EFI.
But thanks for the offer!
Old 03-17-2022, 06:37 AM
Talking SPACER 3.0
Spacer came in and have to say it is a nice piece and clearly resolves any issues I had about any effects with the mixture using an open spacer.
I was hoping those already using this carb would have chimed in on which spacer they used and how it was performing. Oh well.
As much as I don't like the bulk/rise it only adds about a 1&1/2" over the stock carb so my plan to use a Repro Pancake Breather with spacer/collar is not a problem.
Name:	SPACER REQUIREMENTS 3.jpg
ID:	586448   Click image for larger version
Name:	SPACER REQUIREMENTS 4.jpg
ID:	586449   Click image for larger version
Name:	SPACER REQUIREMENTS 5.jpg
ID:	586450   Click image for larger version
Name:	SPACER REQUIREMENTS 7.jpg
ID:	586451   Click image for larger version
Name:	SPACER REQUIREMENTS 8.jpg
Old 03-17-2022, 06:38 AM
Thumbs up Linkage
My friend found a nice 1/4-28 rod in his stash I can use for my linkage.
Old 03-17-2022, 09:17 AM
66sprint 66sprint is offline
Jeff
I remember seeing those adapters hanging on the wall and wondering about the application.
Never considered using an AVS carb on a Sprint but no reason why it would not work.
It looks like you have it just about ready to go. I am interested to see how it runs.
The Following User Says Thank You to 66sprint For This Useful Post:
Old 03-17-2022, 09:34 AM
After doing a little reading , it seems like you made a really good choice using the AVS2.
The AVS design is similar to the QJet as far as the air valve secondaries and the metering rods (which are a lot easier to access and tune).
And the AVS2 has annular boosters on the primaries which should work well with the small displacement engine like the OHC.
Old 03-18-2022, 05:52 AM
Yea, I've been dragging ass for over a year on doing this.
There are no less than 6 other fellow Cammer members who are using the AVS2 with the last being installed onLeno's '68 Bird.
So I figured WTH. I just wish they would/could have shared more details about doing this.
But I'll cover that with mine.
Cheers.
Old 03-20-2022, 07:39 AM
Thumbs up FINAL LINKAGE
Layed out far better than I had hoped.
Clearance concerns were almost non-existent with just some minor trimming to a web on the side of the carb body. Full travel achieved with no binding.
ID:	586654   Click image for larger version
ID:	586655   Click image for larger version
ID:	586656   Click image for larger version
ID:	586657   Click image for larger version
Old 03-20-2022, 07:42 AM
Arrow LINKAGE TRAVEL VIDEO
For those interested click on the Image/link to see a short vid of linage operation;
AVS2 LINK by J. Hamlin, on Flickr
Old 03-21-2022, 08:27 AM
Nice work. That was perhaps the hardest part of my EFI upgrade, redoing the linkage. Looks easy but it is not.
Old 03-22-2022, 06:55 AM
Thumbs up
Yes, I'm really pleased with how well everything is dropping into place.
After studying several other installs and seeing lots of creative linkages I thought I was in for a real challenge.
