Ash Tray Light
I'm getting close to finishing my dash wiring. have 2 items left. a lamp holder on a single red wire with a small hole for light to emit. I think this clips in above ash tray. The other is a similar device on a white single wire with no hole, not sure on this one. maybe it is a mercury switch to turn on ash tray light? can't see anywhere to mount it. Thanks for any help
Without more research it may be for the lighter.
If you have portions of the lamp group, such as the ashtray light than you would have the cigarette light as well. Jeff Hamlin will know. Chris.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
67 Here, one is for cigarette lighter, other is for ashtray.
Red wire to cigarette lighter, white wire for ash tray (look carefully, lamp holder with white wire has small hole in picture). |
One is for the ash tray and one is for the lighter. If you look closely, you will see that one has a small hole and the other has a tiny hole. You should be able to pull the shroud off of both to expose the tiny bulbs. The one with the small hole clips into a spot in the ash tray bracket and the one with the tiny hole clips to the lighter housing.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 02-26-2024 at 07:14 AM. |
Jeff, Do you know if this was an option or did all builds come with this additional harness?
Maybe a standard on GTO's but not on Tempest's, Bob
"Artificial intelligence is no match for natural stupidity". 1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph 1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph |
OPTIONAL
Just under $4
Thank you Jeff,
