Old 08-22-2018, 12:09 PM
Speargun's Avatar
Speargun Speargun is offline
Default Prepping for Dyno Day
I have my first tuning session scheduled for next Thursday on a chassis dyno. What should I do to prep or take with me?
I'll be taking my laptop to tune the FiTech EFI
One step colder plugs. Just installed a set of NGK BKR5E-11 @ .044 last week & have a new set of BKR6E. I had a set of BKR7E, but they were too cold.
Intakes? I'm currently running a Holley Street Dominator, but have a Victor & a Warrior and several spacers.
Basic hand tools.
I'm going to try to get around to swapping out the MSD 6AL for one with timing control this weekend so timing changes are easier.
My combo is:
455 +.060 (469cid)
Fitech 1200
Un-ported E-heads 72cc
10.25:1 scr, 8.7:1 dcr
Hyd roller 583/561, 236/248 @ .050, 106 cl, 110 ls
Doug's headers 1 7/8" primaries. 3" X Pypes to rear quarter exit
Desktop Dyno (version 4.20) says this engine should be somewhere between 550 - 600 hp & tq @ the flywheel, but playing around with different settings in the program that should increase hp & tq doesn't give expected results, so my confidence in it's results isn't very high. For example, adding better flowing heads actually reduces hp & tq.
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
Old 08-22-2018, 12:34 PM
Steve C. Steve C. is offline
Not for your session but curious, is the HSD intake port matched to the heads ?
Old information here:
Old 08-22-2018, 02:03 PM
Speargun's Avatar
It's been a while, but I'm pretty sure that the heads & intake were gasket matched.
No!
Do not try!
Do! Or do not.
Old 08-22-2018, 07:00 PM
surfsama's Avatar
surfsama surfsama is offline
1) Make sure your tires are aired-up.
2) Get the best gas you can find.
3) Make sure you have a video camera(s) ready.
Experiment with your advance and nail it for your combo.
Only a pawn in game of life.
Old 08-22-2018, 07:38 PM
grivera's Avatar
grivera grivera is offline
Originally Posted by Speargun View Post
My combo is:
455 +.060 (469cid)
Do you have dished pistons? Just curious how you arrived at 10.25:1 compression.
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 08-22-2018, 09:50 PM
CraigGT37's Avatar
CraigGT37 CraigGT37 is offline
My son put his Laser on a awd chassis dyno. We made sure the tires were inflated correctly, NO fluid leaks(extra clean-up charge), oil was freshly changed, extra fuel, another set of plugs and tools to change them, and made sure his laptop battery was charged and brought charger just in case.
Old 08-22-2018, 11:04 PM
Speargun's Avatar
Yes. BRC pistons with a 23cc dish
No!
Do not try!
Do! Or do not.
Old 08-22-2018, 11:31 PM
Speargun's Avatar
I hooked up the MSD Digital Programmable 6AL-2 this evening and dropped the locked out MSD dizzy in the car. Now I'm trying to figure out the software to set up my timing curve.
If I'm understanding it right, I set the dizzy at max advance and then use the software to retard the timing back to where it needs to be at a given RPM.
How much max advance do you guys recommend? 36*?
IIRC, I had the old dizzy set up for 18* mechanical, all in by around 3000, initial was around 15* - 18*, and I ran the vacuum advance hooked up.
No!
Do not try!
Do! Or do not.
Old 02-23-2020, 09:23 AM
grivera's Avatar
I know this is an old thread - how did it perform on the dyno?
Will Rivera
Old 02-26-2020, 11:16 AM
Speargun's Avatar
410.25hp @ 5200 & 459.18tq @ 4350 at the wheels.
12.02 @ 113.58 and a 1.84 60' on a dirty track & bald tires.
No!
Do not try!
Do! Or do not.
Old 02-26-2020, 12:49 PM
Speargun's Avatar
And then I broke a rod on Christmas day 2019.
No!
Do not try!
Do! Or do not.
Old 02-26-2020, 01:20 PM
steve25 steve25 is offline
Sorry about your breakage, but your low level of HP and Torque for that motor combo on the chassis dyno was a sure sign that something was not right.
Old 02-26-2020, 01:24 PM
Formulajones's Avatar
Didn't look all that low to me. Greatly depends on the type of chassis dyno, but even assuming the more generous DynoJet, that would be about a 500hp engine at the flywheel and somewhere around 560-570 torque.
That's about where I'd expect a decent 455 with out of the box unported heads and that camshaft to make. Doesn't look out of the ordinary to me.
Old 02-26-2020, 01:29 PM
Are you kidding me!
My Brothers 2006 Vett with just a Cam change and headers made 456 HP at the rear wheels and that's with near 100 less cid!
Your too easy to please!
Old 02-26-2020, 01:42 PM
Are you kidding me!
Well, I am pretty easy to please, lol
But.....
You're talking about an LS engine. Different animial, I've had plenty of LS cars on the chassis dyno There's a reason why the LS swaps are so popular Not to mention the vette is using a pretty efficient transaxle setup (had one of those too) and does a good job of putting power to the tire.
Fact is, a 10:1 455 built like the OP has, with a 236 @ .050 cam, unported E heads out of the box, is going to be about a 500hp engine give or take. Which will put somewhere around 400 to the wheels by the time the trans, converter, and rearend soak it up, along with all the accessories, air cleaner, and exhaust system.
Old 02-26-2020, 01:57 PM
Scott65's Avatar
Scott65 Scott65 is offline
Uh oh, the "L" word's being thrown around...
Old 02-26-2020, 02:01 PM
What can I say, if ya wanna make easy power with just a cam swap, it's LS baby!!
LOL
Old 02-26-2020, 02:28 PM
Scott65's Avatar
No doubt! Doesnt bother me at all. I'm gonna build one myself someday...
Old 02-26-2020, 02:48 PM
A typical 9.5 to 1,.030" over 455's with a hydro roller, iron heads ported to 260 cfm@28" @ 600" , but running only .550" lift will make some 480 hp at the flywheel
480 hp means the motor was using only 240 cfm of that 260 the heads could pass.
Old 02-26-2020, 05:58 PM
Yep, I've seen a bunch of these combinations that are very similar, and built a few. They all seem to fall into that HP and TQ range unless you get really crazy with cam timing and compression. Then people complain about street manors.
Thread Tools
Display Modes
