Old 02-13-2020, 02:15 PM
John Milner's Avatar
John Milner John Milner is online now
Default WFO Air cleaner with Quadrajet Carb
I plan on running a WFO air cleaner with a Quadrajet carb and Edelbrock Performer RPM intake on a '78 Trans Am. I have researched some and a lot of people seem to use a Holley with the WFO setup. However, I will be running a Quadrajet. Does this setup work with a Quadrajet with an electric choke? Are there any problems that I might run in to? Thanks for any input.
Old 02-13-2020, 03:27 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
John I have a Qjet with electric choke and a WFO I'll throw together tonight and see, on a regular drop base I had to drill a hole for the Q jet vent tube.
Skip Fix
Old 02-13-2020, 04:51 PM
Larry Navarro's Avatar
There should not be problem with Q-jet with electric choke. It's tucked in close to the carb body.
However, a hole will have to be bored for the vent tube.
There is clearance issue with the WFO when using the Carter/Edelbrock AFB with the rearward electric choke location.
Old 02-13-2020, 05:00 PM
Thanks Skip and Larry. The WFO setup looks like a great setup. Looking forward to using one.
Old 02-13-2020, 11:16 PM
77 TRASHCAN's Avatar
Yo, Milner, belated Happy Birthday, young man!
Shut it off
Shut it off
Old 02-14-2020, 12:13 AM
Thanks ‘77, they seem to come around a lot quicker every year.
Old 02-14-2020, 07:01 AM
Cliff R's Avatar
Cliff R Cliff R is offline
It may not clear if you don't use the correct electric choke. Many being sold "clock" with the terminal up instead of down. I get carbs in here all the time that have been converted to E-choke using the wrong one so it's 90 degrees out of phase, not down at 6 oclock like it's supposed to be.
Below is a pic of the one I've been selling nearly 20 years now. USA made part, lifetime Warranty and it clocks correctly and works like it's supposed to (release time).......Cliff
https://cliffshighperformance.com/Qu...tail-connector
The Following User Says Thank You to Cliff R For This Useful Post:
Old 02-14-2020, 09:59 AM
Thanks Cliff!
Old 02-14-2020, 12:38 PM
Thanks Cliff. I'll be sure to order the correct choke coil from you when the time comes.
Old 02-26-2020, 10:39 AM
Skip Fix's Avatar
Test fit and the electric choke should be OK just need a vent tube hole.
Skip Fix
Old 02-26-2020, 11:50 AM
Great, thanks for checking. Looking forward to using this setup.
Old 02-26-2020, 12:34 PM
Skip Fix's Avatar
As long as the plug is on the bottom of the choke like Cliff's picture should be close but fit.
Skip Fix
