Radio harness
Does anyone know if there is a new harness available to plug in an am/fm radio to the dash harness? Mine is gone. Thanks
should be some on ebay for very cheap, i got a couple for a 2nd gen firebird for ubder $10 shipped.
As I recall there are two connectors to the radio.. one is larger and has pins for speakers. The other is smaller and provides power. I remember the smaller one being inexpensive and readily available but the larger is harder to find and costs more. I do not think the "correct" large connector is reproduced. The smaller actually "stacks" onto the larger one.
I think this is an example of what you are looking for and I think this price is typical for used on eBay: https://www.ebay.com/itm/1970-1971-1...cAAOSw54NeTtdu |
shiny has the right feel for the plug you need
the chevelle plug is quite a bit different but the way they work together is the same the chevelle one looks to have a partial rear speaker fader harness t oo here is a 68 pontiac 3 prong horizontal plug yellow is power green and black front speaker/main plug then the 69 went vertical with the speaker plugging into the power plug ... kinda opposite in all ways from 68 here is a picture ..with the speaker the small outer plug and the power and ground and rear speaker in first. Scott fairly sure the 69 plug is A B F body cars 69-72 maybe 73 74 I have seen them in clear... brown... and black plastic |
Thanks for the help and pictures everyone. Looks as if I’ll need to source a good used one.
Delco made a kit too. Were like $10. I have a few, it comes with a pack of crimps that push in the 3 plugs that come in the kit.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
the whole harness..all of it repopped and pretty reasonable...some dude hand makes them, he does runs and when he sells out he will do more..this guy also refurbishes harnesses etc...i dont know him, but ive bought his stuff..he seems to be a real good guy..very knowledgeable too
he is on ebay https://www.ebay.com/sch/themrgrandp...p2047675.l2562
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered." |
Yes, I think a used/refurbished set is probably your only option but you could also use discrete wires and pins if you were motivated.
I could not find a source for new/repro 5-pin connector housings that mate with this connector on the stereo radio: The mating 5-pin housings are usually expensive on eBay: https://www.ebay.com/itm/1969-CAMARO...cAAOSwwp9duITZ It wasn't clear what was missing from your car but if only the 3-pin "power connector" and not the 5-pin "speaker connector" you might be in a better place for finding used housings/harnesses. The brass pins are standard and available new for male and female so you can renew yourself (replace pins and wires) if you have the connector housings. You could also just use pins and discrete wires to the radio connector (ie no housing) if you were hell-bent on function at low cost. The "pass-through" pins that allow the "piggyback" power connector to plug into the 5-pin housing are NOT readily available. These are weird parts but allowed the use of a standard power connector (the piggyback) with multiple radios. The seller linked by Marxjunk is a good source for refurbished parts. I don't think he has any "correct" basic (non-8-track) harnesses listed now but you could contact him to see if he would build one for you. I bought some of the "pass-through" pins from him to rebuild my harness. They allow the "piggyback" power connector to plug into the 5-pin housing. These pins are also not easy to find so seem to be a used-only item: https://www.ebay.com/itm/5-USED-DELC...gAAOSwU1FZ-RVt You could also call S&M (Turnswitch) and see if they could help. They were awesome for me when I needed some used parts: http://www.turnswitch.com/feedback.htm If I recall correctly, the front speaker wire comes out of the 5-pin connector and the rear speaker, dial light power, and 12V radio power are all in the "piggyback" connector housing. The grounds including the speakers are through the chassis. There is a separate blue? wire harness that runs under the carpet to the rear speaker. Not sure what year/radio you are working on but if it is a 70-72 non-stereo AM/FM or 71-72 AM/FM/Stereo (no separate multiplexer) the wiring is really this simple.. Here is an AM/FM diagram from my 70 book that I think should be the same for 71-72 AM/FM/Stereo. It shows the 5-pin connector, 3-pin "piggyback" connector, and the separate rear speaker wire (harness): More complicated if you have a 70 AM/FM/Stereo or 8-track I'm sure! And I'm still baffled why Pontiac had left and right stereo channels going front to back instead... slow to change but must have been weird listening to left and right source channels coming from the wrong places!! |
Thread Tools | |
Display Modes | |
