Old 02-24-2020, 11:49 AM
DarcyL DarcyL is offline
Default Preferred Fel-Pro gasket set for 455
Hey all, I'm going to order a gasket set for putting my 455 together, 6x heads, cast 1972 intake. I see there are 4 or 5 different Fel-Pro kits- is there a preferred go to kit I should get? Thanks,
Darcy
Old 02-24-2020, 01:38 PM
Lee's Avatar
Lee Lee is offline
Sealed Power 2601025
The gaskets in it are the same FelPro gaskets you get in the other kits, but this is usually less expensive.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 02-24-2020, 01:47 PM
chiphead's Avatar
chiphead chiphead is offline
Does that include the FelPro 1016 head gaskets? Those are the ones I always use.
Old 02-24-2020, 09:56 PM
77 TRASHCAN's Avatar
The 1016 head gaskets are only sold separately.
Shut it off
Shut it off
Old 02-24-2020, 10:28 PM
76TA462 76TA462 is offline
For my 455 builds, always been FelPro 1016 Head gaskets, 1233 Intake Gasket
Old 02-24-2020, 10:32 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
The Felpro 1016 Head Gaskets are also included in the Felpro 2806 High Performance gasket set, we just used one on a 400 that we built. The set also includes the Felpro 1233 printoseal intake gaskets.
1978 Trans Am
Pump Gas 461 Stroker
Old 02-25-2020, 02:02 PM
Lee's Avatar
Lee Lee is offline
I NEVER use the 1016's, just the standard 8518's. I've seen 1016's leak coolant a few times, but have never had an issue with the basic 8518's, even with aluminum heads and 11-second street cars.
To each, his own. The Sealed Power 2601025 usually cost me about $65, and have worked great for me for the past 30 or so years.
Old 02-25-2020, 03:27 PM
Hmmm.... First time I've heard of someone having problems with the 1016 gasket. We have used several sets of them on different builds over the years, and have never had a problem with them, atleast not yet anyway.
1978 Trans Am
Old 02-25-2020, 03:35 PM
steve25 steve25 is offline
I've reused the 1016 gaskets on my 455 blower motor 3 times, on the second time all I did was apply a film of blue gasket maker around the water passage holes and had no issues.
The head deck and the block deck must be good though, without even a hint of rust around the water holes.
Old 02-25-2020, 04:00 PM
Lee's Avatar
Lee Lee is offline
It was late 90's / early 00's, but I saw 3 different 1016 equipped motors leak water. Maybe there was some temporary issue back then, and it has been resolved. But after having NO issues with the cheaper 8518's, I see no reason to buy the 1016's.
Old 02-25-2020, 06:12 PM
Thanks for all the great info!
Darcy
Old 02-26-2020, 01:19 AM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
I to had a 1016 head gasket leak as well from late 90’s early 2000 I now use 8518 head gasket.
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Thread Tools
Display Modes
