Old 02-26-2020, 09:46 AM
GoGoat GoGoat is offline
Default Ash Tray Light
I'm getting close to finishing my dash wiring. have 2 items left. a lamp holder on a single red wire with a small hole for light to emit. I think this clips in above ash tray. The other is a similar device on a white single wire with no hole, not sure on this one. maybe it is a mercury switch to turn on ash tray light? can't see anywhere to mount it. Thanks for any help
Old 02-26-2020, 12:13 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Without more research it may be for the lighter.
If you have portions of the lamp group, such as the ashtray light than you would have the cigarette light as well.
Jeff Hamlin will know.
Chris.
Old 02-26-2020, 12:24 PM
Old Goat 67's Avatar
67 Here, one is for cigarette lighter, other is for ashtray.
Red wire to cigarette lighter, white wire for ash tray (look carefully, lamp holder with white wire has small hole in picture).
Old 02-26-2020, 01:27 PM
One is for the ash tray and one is for the lighter. If you look closely, you will see that one has a small hole and the other has a tiny hole. You should be able to pull the shroud off of both to expose the tiny bulbs. The one with the small hole clips into a spot in the ash tray bracket and the one with the tiny hole clips to the lighter housing.
Old 02-26-2020, 07:13 PM
Jeff Hamlin's Avatar
Thumbs up
Old 02-27-2020, 09:22 AM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
Originally Posted by Jeff Hamlin View Post
Jeff, Do you know if this was an option or did all builds come with this additional harness?
Maybe a standard on GTO's but not on Tempest's,
Bob
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph
Old 02-27-2020, 06:48 PM
Arrow OPTIONAL
Old 02-27-2020, 06:51 PM
Smile Just under $4
Old 02-28-2020, 09:22 AM
Thank you Jeff,
Thread Tools
Display Modes
