Old 04-24-2024, 07:17 PM
Default 64 GTO PHS
64 GTO PHS Baltimore Plant
This appears to have been a 78X 3spd 4bbl
Is "RB" the correct trans code for 3spd ?
Seem to remember Baltimore coding is all wacky ,,, I think.
This car is only physically presenting
Power Steering and Power Brakes
Console , Back-Up Lights , Manual driver side mirror
and some 65 style standard seatbelts
Is there anything missing or added compared to PHS ?
Old 04-24-2024, 07:22 PM
It has a complete 78XW engine about 100,000 units too early
And a 4spd
Nice solid looking convertible
Skyline Blue , Blue Interior , White Top
https://bringatrailer.com/listing/1964-pontiac-gto-78/
Old 04-24-2024, 08:01 PM
Shame there’s a Chevy air cleaner lid on it instead of the lovely original chrome unit with the short snorkel.
ID:	632577   Click image for larger version
Old 04-24-2024, 08:23 PM
b-man refresh my memory if you can .
Where is the casting date on 64 - 4bbl intake - - rear - or bottom
And casting dates on 64 - 9770716 heads - - underneath covers - or below the exterior rail
In case the seller wants to get down to brass tacks
Those air cleaners have always been few and far between.
Once in a while I would luck up on a 326 HO car with a painted 4bbl version of it.
The top piece was the same on all the 326 2bbl - but painted
Old 04-24-2024, 09:00 PM
Intake date codes are on the bottom of the intake and head date codes are under the valve covers.
Old 04-24-2024, 09:29 PM
Thanks Bart
I doubt the seller will want to get that deep.
But he could still check the block date on a clean engine pretty easy.
Old 04-25-2024, 07:35 AM
johnta1 johnta1 is online now
What's the EUN are you using?
I have it at about perfect for it.
I also can't find my notes on the tranny code, but should be in the GTO 'Bible'? (that is buried at the moment)
Old 04-25-2024, 10:54 AM
The EUN for the original 78X on the PHS / PoP imprint should be perfect.
326254. ( 06B body date)
The EUN for the current 78XW that is installed is about 100,000 units earlier than that.
225103
Old 04-25-2024, 11:49 AM
Just found an old 2009 post from John V that "RB" is for 4spd Wide Ratio
Still hunting info
Maybe the X on that particular PoP from Baltimore was generic
And it should be a 4spd 78XW engine code.
Old 04-25-2024, 12:07 PM
Hmm...
I copied the info when that it 1st came out and my pic seemed to show a '5' start, your pic in post seems pretty clear.
To me the eun I had fit good, 526254 for a 6B body.
Old 04-25-2024, 01:37 PM
John
The whole point is the engine now in the car has EUN 225103
That isn't anywhere close whether the PoP number starts with a 3 or a 5
The engine in the car starts with a 2
It doesn't resemble the number on the PoP in any form.
As in it is not the born with engine.
Car was claimed to be numbers matching
Old 04-25-2024, 02:25 PM
Evidently John V. is the only one left standing who can cross the Chevy code numbers on these.
I googled everything I can think of and can only find RPO codes such as C60 D55 M40 for Chevy
Code 303 and Code RB both equal 4spd
So it was not a 3spd car
78 XW would be proper block code with a 3K / 3.23 posi
Have requested seller to verify the block casting date and gave instructions.
Old 04-25-2024, 02:42 PM
I see what your getting at. ( I just wrote the numbers from POP)
Agree 100%.
Old 04-25-2024, 03:57 PM
Using a couple of John V.'s previous deciphered Baltimore 64's
So far have this :
303 = 4spd
31D = 389 4bbl – GTO use only
321 = Posi
342 = ( this box is usually where power brakes and power steering codes are)
the #2 should represent power brakes
350+366 are combo codes = White line Tires
44C = (this box is usually where radio equipment goes)
the C should represent the AM pushbutton radio with manual antenna
62A = Console
Still 5 more Codes to account for
431
452
461
482
531
I see Back Up Lamps , Dual Speed Wipers , Driver Rearview Mirror
That will be 3 of the 5
I also see Pwr Steering , but that should probably make box 34 into a 3 instead of a 2 (combo of #1 and #2 = 3) maybe.
Old 04-25-2024, 06:04 PM
From John V's article in Smokes:
box 30 is for 4 speed wide ratio
box 44 - C: Pushbutton AM radio– manual antenna (Pontiac Sales Code 392)
box 45 - 2: Windshield washer w/dual-speed wipers (Pontiac Sales Code 421)
box 46 - 1: Tinted glass– windshield only (Pontiac Sales Code 532)
box 48 - 2: Custom wheel discs (Spinners, Pontiac Sales Code 521)
box 53 - 1: Ivory convertible top
box 62 - A: Floor console (Pontiac Sales Code 601)
Old 04-25-2024, 06:46 PM
Thanks John -- Great !
Anything on #431 - possibly back up lamps or driver side rear view mirror
Old 04-25-2024, 07:38 PM
HD Air cleaner possibly for 431
That's actually the sales code for 431.
Box 43 - 1: Back-up lamps (Pontiac Sales Code 471)
Old 04-25-2024, 08:53 PM
Process of elimination
431 has to be Back Up Lamps
I went ahead and posted it .
Thanks John
Car is really really honest overall
The steel blue-gray accents on ribbed dash trim, heater control, console, all looks original unrestored.
Pretty tight on a convertible 60 years old .
Old 04-25-2024, 11:16 PM
I got that wrong about the ribbed dash trim , color has been removed.
That's a real pretty color combo , I think it will sell.
Lot of RNM endings on BaT lately.
