Old 09-19-2011, 05:16 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
We make a semi-custom bracket that mounts the "BK" code 1985-87 dual 9" booster on different cars. The test car is a 64 Catalina; we will get some pics and post them. The later booster allows 66 and later masters to be used.
Would like to see them if you have them...
Also I swapped out the lines. Front reservoir goes to front brakes etc.. Car brakes were still VERY touchy. But I put 70+ miles on the wagon yesterday and the more that I drive the car the better they get. Meaning the feel of the pedal. I think that there might have been a lot of rust on the brakes or what ever, cause they feel great now.
I would still love to get a front disc set-up that uses 14" rims.....
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
  #102
Old 09-19-2011, 09:20 PM
61 vent 61 vent is offline
Scarebird, have you had time to take a few pictures of your bracket?
  #103
Old 09-11-2014, 05:29 AM
mkoser's Avatar
mkoser mkoser is offline
I know this is an old thread, but I though I would bring it up again to seek feedback.
Does anyone that has done this conversion have any input?
I did mine in 2011, and have not had a lick of trouble since then. I've put a few thousand miles on. I've had no leaks, and no braking issues.
I still haven't cleaned up my "test-fit" brake lines to the master. I have work to do yet. I think I'm finally ready to throw my old single master in the trash. I held onto it "just in case."
Thanks,
  #104
Old 06-25-2015, 09:48 AM
Keith Seymore's Avatar
Subscribing (so I can find this when I need it).
Just lost the brakes on the GP last night (single system). Made it home safely by downshifting the trans and with what little brakes I had left, but getting the car in the garage was a challenge!!
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
  #105
Old 06-25-2015, 10:20 AM
Some of you know that I was a brake development engineer for GM light truck at the Desert Proving Ground in the early 1990's timeframe. My (professional) experience is therefore limited to dual systems but hopefully it is still ok for me to make some general observations:
a) Not to put words in mkoser's mouth but it seemed implied to me the thread was to discuss drum/drum systems. References to disc/drum systems tended to confound the issue and probably should have been avoided.
b) References to the master cylinder port location should be made from the perspective of vehicle position. That is, the front port is the one closest to the front bumper; the rear port is the one closest to the rear bumper. Any other frame of reference causes additional confusion.
c) In my development experience, even within modern dual systems, there were some that were front to front and some that were front to rear, depending on other considerations like hood clearance and relative reservoir size based on vehicle platform* In those cases it was obvious what the intention was, since the large reservoir would be for the front disc system. My point is that I wouldn't be surprised if early cast iron dual master cylinders had similar variation and it would be ideal if the part itself could tell us which way it was to be hooked up, similar to my aluminum master/plastic reservoir analogy. Since we are specifically discussing a '69 Bonneville m/c I wonder if the '69 chassis manual would provide any insights...
d) I have the brake system release charts for all LD pickups, starting in 1969. I'll take a look and see if they reference which port feeds which brake system (front to front vs front to rear).
e) I believe this thread was an excellent resource and am glad it is still available as a reference.
K
*example - the old M/L Astro/Safari mini van. The sharp hood angle cause the rear reservoir (located toward the front of the vehicle) to be miniscule in height. I tried one of these master cylinders on my Chevelle and, while it worked well for pedal feel/effort/travel, the angle of the installation meant that I had to jack the rear of the car up in order to put brake fluid in the rear system or to bleed the brakes.
'63 Grand Prix
  #106
Old 06-25-2015, 11:28 AM
K
You may be able to simply switch reservoirs, from say a 81-87 G body.
  #107
Old 06-25-2015, 11:54 AM
MOJO Catalina's Avatar
MOJO Catalina MOJO Catalina is offline
Send a message via AIM to MOJO Catalina
K
Scary situation.. I lost brakes in my '63 GP pulling into a parking space at a grocery store.. Luckily there were bushes in front of the space that were about 5 feet tall and had been there for 10 years. I usually park just anywhere but on that day Chief Pontiac must have been watching over me.. The pedal grabbed for a split second then went right to the floor.. I sailed right into the bushes.. No damage, just bent the bush out the other side.. When I pumped the brakes a few times they started grabbing again.. the seals in the MC must have gotten some rust buildup around them, allowing the fluid to blow by them.. I abandoned the grocery run and drove home slowly with one foot on the Emergency brake... It could have been bad if I'd plowed into a car or someone and their cart.. Did the dual swap the next day.. ( car sold years ago) Now both my drivers have them. The '60 Cat is manual drum/drum and the '63 BV is power drum/drum..
Sometimes towed but never trailered!
  #108
Old 07-11-2015, 09:39 AM
K
Ok - so I've gathered all the parts and have started the teardown....and already hit a couple snags.
a) I'm using the Autozone M-1328 master cylinder for a '69 Bonneville. I've added the adpater fittings to the outlets and, when I position the master cylinder, I've got hard contact with the wheelhouse inner. There's not enough room to add a brake line and make the turn. Anybody else experience this?
b) The removed single pot master cylinder has a very deep bore in the piston for the push rod; the new master cylinder has just a small dimple to position the push rod. I'll need to take quite a bit off the push rod but - how does it come out from the booster? When I pull on it it comes out a bit but feels like it is attached to a/the diaphram and sucks back in when I let go.
c) I sent a note to one of the brake engineers relative to the port placement. He was off for the GM shutdown but I'll let you know once he replies.
d) Do you all have a preference - should I keep posting here or should I start a new thread specific to my conversion?
K
'63 Grand Prix
  #109
Old 07-11-2015, 11:26 AM
Stuart's Avatar
Stuart Stuart is offline
I seem to recall that the push rod is either attached to the booster internals or is a separate part, depending on what brand your booster is - Bendix or Delco-Moraine.
  #110
Old 07-11-2015, 02:44 PM
Thanks, Stuart.
I found a vintage (1978) Delco Moraine design handbook which shows it clipped to the diaphragm.
I can probably rework it in place but I thought it would be easier to put the point on the end with it out of the car.
K
'63 Grand Prix
  #111
Old 07-11-2015, 06:57 PM
ornjcr8 ornjcr8 is offline
no...no, keep posting with your project. I live by Rochester and once your get yours done I know you will want to come over and do my 62
  #112
Old 07-13-2015, 11:57 AM
Not particularly helpful but I thought it was cool to look at the old document (from back when everything was done by hand).
K
Name:	69 power brakes 1.JPG
ID:	402620   Click image for larger version
Name:	69 power brakes 2.JPG
'63 Grand Prix
  #113
Old 07-18-2015, 11:26 AM
64catalina 64catalina is offline
Default Brake conversion
On my 64 cat I believe the original pushrod was attached with a collar and pin w/clip.
New one had threaded rod and collar.
I have a question with all due respect to everyone here.
I have done the conversion on my car.
I am curious, why would you collect all the parts and pieces versus an established kit?
Not trying to stir up stuff just curious.
for me it was knowing I had what would work so I could be back on the road asap...
There is no good luck, its just what you make out of what you got...
  #114
Old 07-18-2015, 12:32 PM
Is there an established kit?
I have to stay drum/drum because I'm keeping the 8 lug aluminum wheels.
K
'63 Grand Prix
  #115
Old 07-18-2015, 10:50 PM
I looked around a lot and master power brakes was the only one I found that would guarantee fit. disc upfront original drum in back.
uses calipers etc from a late 70'early 80's chevy all new parts with power $900 give or take
Came with everything but the ability to bend a really tight brake line..
  #116
Old 07-20-2015, 07:24 AM
Any input on why I'm crashed hard into the wheel apron?
It looks to me like I need ports on the inboard side of the master cylinder.
K
Name:	Master Cylinder 1.JPG
ID:	403294   Click image for larger version
Name:	Master Cylinder 2.JPG
'63 Grand Prix
  #117
Old 07-20-2015, 07:41 AM
Did you have manual brakes? Normally, the brake booster, (with power brakes) would move this up and out of the way. You might need a 90* adapter.
The Burb Files
  #118
Old 07-20-2015, 07:49 AM
Nope - always been power brakes.
My parts guy said they don't make 90 degree adapters (which accept a brake line flare).
K
'63 Grand Prix
  #119
Old 07-20-2015, 07:56 AM
K
HMMM... I might have to say BS on that. If I get some time I will go to the "real" auto parts store and dig through the Weatherhead bin and see. Is that 3/8s in the front and rear of the new master cylinder?
The Burb Files
  #120
Old 07-20-2015, 11:27 AM
Default brake upgrade
Those 90's are hard to find. I had the same issues.
also I did not want put distribution block far away.
Here's what i wound up with...
ID:	403305   Click image for larger version
ID:	403306   Click image for larger version
