Old 10-08-2023, 08:10 AM
Jimbobeast Jimbobeast is offline
Default RA IV vacuum
My stock 1970 RA IV is producing 11" of vacuum at 850 RPM idle, dwell 30, initial advance 15. That vacuum seems a little low to me but the engine does make a nice lopey sound at idle. Is that manifold vacuum acceptable? I'm not able to drive the car yet.
Thanks,
Jimbo
Old 10-08-2023, 08:00 PM
74Grandville 74Grandville is offline
i'm not an expert on RAIV, but i think that is normal for factory 400 RAIV. That is a big cam!
i'm running a crower solid 60311 in a 428 at 10.6:1 compression and only see ~6-7 hg. i think of this as the solid version of the RAIV cam.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
The Following User Says Thank You to 74Grandville For This Useful Post:
Old 10-09-2023, 08:17 AM
Half-Inch Stud's Avatar
11" in gear cold is pretty good, warmed-up should be a tad better.
Seems low, or not so good in neutral. Adj idle mixture screws for highest vacuum (or rpm incease, usually done in gear with two people For safety).
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 10-09-2023, 08:52 AM
steve25 steve25 is online now
How many miles are on the motor?
How’s level of compression balance between all 8 cylinders?
Is the compression still stock, as in pistons used?
Has a valve job been done to the heads?
Old 10-09-2023, 09:52 AM
mgarblik mgarblik is offline
Assuming all the above is in good health, that vacuum reading is a little low. However, as has been stated, big cam, relatively small engine= low idle vacuum. What is the vacuum reading at 1000 RPM's and 1200 RPM. I would expect around 13" @ 1000. Did you degree the cam when it was installed? Is the needle on the vacuum gauge steady or jumping around? (possible valve adjusted too tight) Are you sure your vacuum gauge is accurate. Do you have another known good gauge to compare it to? If it seems to be running OK, I wouldn't be too concerned at this point if it comes up at 1000-1500 RPM's.
Old 10-09-2023, 10:58 AM
Ram Air IV Jack's Avatar
Ram Air IV Jack Ram Air IV Jack is offline
11" of vacuum at those settings is about right. My original runs about 11"-12" at 750 to 800 rpm! That 87 degree overlap 041 cam is a lot and the vacuum will be low. I've seen cars back in the day with non-stock performance cams so wild they hardly activate the power brakes near idle. I had a stock RAIII car with the 744 cam years back that had relatively low vacuum at idle, but it wasn't quite as low as the RAIV engine. Very few original RAIV engines exist today and the ones that do have been worked on, bored, modified, etc. many times over which will affect the idle vacuum. However, your figures are normal for a stock RAIV engine!
Old 10-09-2023, 01:10 PM
Thanks for all the replies. Zero miles on this engine, all stock, machined and blueprinted by a Pontiac veteran machine shop, cam degreed when installed, steady reading on top end vacuum gauge, stock compression, vacuum 14" at 1100 RPM. The only worry was the valve springs, as this motor was assembled by me 15 years ago. I left the rockers very loose for all those years and turned the engine over by hand every few months.
I still have some fiddling to do with the timing and idle mixture. I'll report to the forum if any improvement.
Old 10-09-2023, 01:33 PM
14" HG@ 1100 RPM's is normal for that camshaft. Enjoy the pull starting at 3000-3200 RPM's!
Old 10-10-2023, 09:05 AM
69hardtop 69hardtop is offline
Thanks,
Jimbo
11-12 inches of vacuum is exactly what my 69 400 with 041 cam produced at idle.
