SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 12-05-2023, 05:23 PM
Apache Warrior's Avatar
Apache Warrior Apache Warrior is offline
Default Engine Run Stand F/S
Zip code 60084 (Chicagoland Area).
Purchased new from Summit Racing Equipment.
Upgraded to 8” heavy duty casters to clear engine hoist.
Added:
Gauges
Tachometer
Throttle cable
Radiator overflow tank
Wiring junction blocks
Wiring
Battery
Battery box
1 Gallon fuel cell (aluminum)
Fuel hose
Aeromotive A1000 pump (gas/e85)
Hoses
Fittings
Remote oil filter housing
One way fuel shut-off valves
Central grounding bar
Fire extinguisher
Lakewood bell housing
Bellhousing bolts
MSD 6AL ignition box
MSD coil
Lots of wiring
Add your motor, with specific motor mounts, wiring connections, exhaust, gas and you’re done.
No radiator.
No block saver plate.
Will not separate.
$1,500.00 firm.
Will not ship.
Brackets accept a radiator just under 3” thick.
https://www.summitracing.com/search?...%20Run%20Stand
See pics.
ID:	624477   Click image for larger version
ID:	624478   Click image for larger version
ID:	624479   Click image for larger version
ID:	624480   Click image for larger version
Old 12-05-2023, 05:32 PM
Default More Pics
See Added Pics
ID:	624487   Click image for larger version
ID:	624488   Click image for larger version
ID:	624489   Click image for larger version
Old 12-05-2023, 10:00 PM
pontsd pontsd is offline
Pm sent
Old 12-06-2023, 04:03 AM
Dragncar Dragncar is offline
Very nice, think I will make one . Have a old Lakewood laying around.
Its worth what you are asking.
Old 01-26-2024, 11:52 AM
Run stand is sold.
Thank you PY.
