transmission fluid
Guys what transmission fluid are you all using in your performance transmissions? I have a manual valve body th400.with a 9" converter. Was told that type F was a little better than dextron II so thats what I have been using. Any thoughts?
I've always run this in my automatic transmissions…
http://www.mikestransmission.com/cat...miscparts.html
1963 Tempest Convertible Pontiac-Powered Funny Car: 400 block, Littlefield 8-71 blower, Enderle injection, custom blower intake, three-disc glide clutch, three-speed Lenco |
Scott I have always just used napa trans fluid, I think it is mercron 3 ! never any trans problems!yet, we will see afteryour wide ports go in front of it!
Gene Kinch 1969 firebird CVMS 468,t-400,9inch 3.50 rear 11.58@116 1979 TA 462,t-400 3.23 10 bolt 12.76 @ 108 1971 GTO 400,t400 3.23 10 bolt all original 14.41@96 1968 GTO Gallop-n-Goat race car CVMS 462,pg 4.56 12 bolt eheads 5.98 @115 on e85 1995 Jerry bickel ex-pro stock Firebird,sonny leonard 632,Glide,9 inch 4.10 rear 7.08 @198 ( crashed and under reconstuction) 1979 TA, 400/ 4 speed all original needs restoration. 1999 Trans Am LS1 |
John Deere hydrolic oil with one quart of Mobil 1 trans fluid to give it some color.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
Gene..I cant wait to see how your gto runs with the heads...
Jack..really john deere hydraulic oil? |
Type F here, never a issue.
B&M Trick Shift.
Amsoil
GTO George |
Yep it's cheap, and if you want to tighten the converter up 100-200 HP that does the trick.
John Deere Low Viscosity Hy-Gard Oil to be specific. Do not use the original Hy-Gard
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
Any type F I can find easily. It's getting a little rare at the corner parts store.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
x2... I've been thinking about switching to the Hydraulic tractor oil though.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
X2..Same here but i skipped the coloring part
6.98 @ 199mph 4.53 @ 164mph |
the ATF that MONSTER TRANSMISSION in Florida recomends for there trannys
color me gone |
I've used the PTC fluid which looks like the JD to me...
This time I used the Mercron III ....???? Might dump it for the JD stuff..
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
John Deere hydraulic fluid. I buy it in the 5 gallon container and use it in all my automatics.
John Deere green
John Deere hydraulic oil low viscosity HRYDA.
505 KRE HP head 2x4 HP 1000s 60' 1.33, 5.78 @ 120.88MPH in 1/8 9.11@149.8MPH in 1/4 |
50/50 Type F and Dexron, would have liked to use the JD low vis. but my convertor is too tight as it is.
Do ya'll paint your transmissions green as well?!
Where did this JD hydraulic fluid idea come from? Rich
68 Firebird 400, #16, xe274, street dominator, 850 DP, hooker headers, t400, 3500 stall, 3.73, 295/65 bfg drag radicals... best 13.27 @ 102.8, 1.90 60ft |
