Old 07-14-2020, 02:37 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
Default 428 Value
I saw the other post on 455 value and instead of stomping on that thread, I have a similar question....
I'm thinking of unloading a '69 bare YH 428 block with matching 4 bolt caps. Standard bore and has been tanked/verified. Super nice. What's the going rate for something like this these days?
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 07-14-2020, 02:44 PM
Are you sure it has 4-bolt caps? Most 1969 YH 428 blocks were tapped for 4-bolt mains but were fitted with 2-bolt caps. The 69 YH motor came with "46" small valve heads.
I had a 69 360HP 428 with 4-bolt caps, but it was a WG coded engine out of a manual tranny car. It also had "62" heads.
Mike
Old 07-14-2020, 02:51 PM
Yes, positive it has 4 bolt caps that are original to it. This isnt the first 4 bolt YH I've had.
So, back to the topic any opinions on VALUE?
Old 07-14-2020, 02:59 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
I've seen 428 blocks going for $750-1500 for a good core (towards the higher end for 4 bolt main cap blocks) and $2000+ when they run, but it's been a while since I've been in the market for one. They're similar in value to a 455 but their market is more geared towards date code guys in my experience as the general population likes bigger cubes.
Old 07-14-2020, 03:28 PM
Singleton Singleton is online now
In my area, $500-800 would sell it, if patient enough.
I've never seen a '69 YH with 4-bolt caps though. I have a '67 YH with 4 bolt caps, but then again, all 67-68 428s were 4-bolt cap
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
Old 07-14-2020, 03:54 PM
Checked the dates and it's a 68 block not a 69....sorry for confusion
Sent from my SM-G973U using Tapatalk
Old 07-14-2020, 04:07 PM
I sold a 428 4 bolt shortblock never apart the yh code also less than 1 year ago $1000.00
Old 07-14-2020, 04:55 PM
Default At least $1000 for a standard bore 4-bolt main that has been magged
Probably closer to $1500 if it's sold to someone close who doesn't need it shipped. Too bad you're not a little closer........
It would be a great block for someone who has new 455 std bore pistons and crank to build a 'stock dimension' 455 with.
Love those 4" stroke motors!
Good luck!
Old 07-14-2020, 07:30 PM
vertigto's Avatar
vertigto vertigto is offline
Y'all should enjoy this...
https://greensboro.craigslist.org/pt...150650966.html
Old 07-14-2020, 09:35 PM
marxjunk marxjunk is offline
$1k-ish
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 07-15-2020, 07:02 PM
John Eiseman's Avatar
John Eiseman John Eiseman is offline
Agree w/.Mark. If its clean and been magged 1000.- is a good deal for a 4 bolt block.
Is it standard bore or oversized ?
