Old 06-26-2016, 01:12 PM
dld's Avatar
dld dld is offline
Default rear upper body panel
One or more of you have the answer to this one.
last weekend I was at Pypes show and the question came up about the upper body panel on a 65 vert. this is the panel below the top window between the 1/4's. the h/t and post cars the seam at the 1/4's is showing or unfinished.There was a strong contingency there that said the seam was filled or not showing. several 65's there did not have the seam .
whats factory??
buy the way show was Well attended . good cars there.
Old 06-26-2016, 02:51 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Hey Don. What's up??
I believe the 64 and 65 conv. are the same and seam should be lead filled. The hard top and coupe should not be filled. That actually came up at a GTOAA show last year or the year before... "Bill"!
Old 06-26-2016, 02:56 PM
This is what I've always seen on these cars.
Converts have the seams filled with lead at the factory, usually the lead filler is cracking a little too.
Post and hardtop cars never had those seams filled.
I have a '64 Tempest post coupe still in the factory original white paint and the seams are as they should be, not filled.
Old 06-27-2016, 10:31 AM
dld's Avatar
dld dld is offline
hi. Bill thanks for info.
the 66 cars we looked at had the seams showing. on the vert. cars. this is where I was confused on issue. one guy at show said seam was brazed. I know that's wrong just because of time. I agree about the lead. funny that 66 up had the seam showing.
thank b man also.
