Old 07-13-2020, 04:16 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default 1966 421
I picked up complete engine this weekend. Taking it to the machine shop tomorrow to get the block and crank checkout. This is going to be for sale providing everything checks out. Looking for an approximate value. It's a YH block with 92 heads single four barrel. 4bolt main block. Looks to be standard bore right now.
Old 07-13-2020, 07:50 PM
$1500 if the block is standard bore and the crank is still standard on all the journals. If it had #93 heads instead of the #92 heads the value would be closer to $2k.
All 421 engines have 4-bolt mains.
Old 07-13-2020, 08:25 PM
Bills Auto Works's Avatar
Bills Auto Works Bills Auto Works is offline
Thanks Bart,
You answered a question I always wanted to ask, but always forgot to! ABout all 421s being 4 bolt mains!
Ironically mine goes to the machine shop tomorrow as well, but because I found some serious problems & since I bought it a couple of years ago, no recourse. Looks like some idiot had the crank cut 10 & used standard bearings. All 3 center mains spun & took the tabs off the backs. I am getting everything ready to leave for California or I would have checked the crank size myself, but now we will see what the shop says regardless. They will have some time to go over it while I am on the road.
It is a WG with 76 heads
God Bless
Bill
https://www.jalopyjournal.com/forum/...closed.614419/
Your QUALITY Pontiac Transporter
Bills' Auto Works Est 1983 & still going strong!
1955 Chevy Altered W.B. Gasser
1955 Nash Ambassador Custom Lemans
1957 Chieftan 2dr HT
1964 Grand Prix
1966 Catalina Conv. 421
1966 Ambassador DPL 2dr HT
1966 Ambassador Cust. 2 DR HT
1967 Marlin
1967 Toronado
1973 Nova Full Chassis Car
1992 Jag XJS Conv
1992 Jag XJS Coupe
2007 Cad XLR-V Supercharged Roadster
Old 07-24-2020, 12:55 PM
hobbygto65's Avatar
Got the block and crank back today. Block is good, needs to be bored .040 over. Crank is armasteel, needs .020 on mains and .010 on roads. I would guess this is about normal wear for engine this age?
Old 07-24-2020, 03:04 PM
geeteeohguy's Avatar
Without knowing the history, perhaps. Most of the Pontiacs I've gone through needed a .030" overbore and .010/.010 on the crank, so yours has either been rebuilt once before or has had a bit harder service. Others with more experience will chime in. I've built a few Pontiacs, many here have built dozens of them...and more.
Jeff
Old 07-24-2020, 03:15 PM
hobbygto65's Avatar
The block and crank are standard, bad ridge in cylinders require the .040 overbore and it looks like they wiped a bearing on the one crank journal.
Old 07-25-2020, 05:35 PM
Without a vehicle or mileage, impossible to accurately guess. From your description, it sounds like an honest, never rebuilt engine that has suffered wear from decades of use and is now in need of a rebuild. I've seen near identical mileage old engines vary greatly in condition: light usage and regular oil changes and tune-ups = little wear. (the 400 in my '67 GTO had no real ridge at 173,000 miles and the crank was fine). I've seen other engines that pulled a boat or a trailer, ran hot, and ran a long time between service intervals. Those engines showed more wear. Your 421 sounds like an easy re-fresh and will be a cool engine for somebody! It's my favorite 'big journal' engine.
Jeff
