Test & Tune Ask questions about the features and functions of the Forums. |
Picture in Signature
I can't get my signature picture to show up with my posts. When I go into the edit signature fuction under the User CP, I can see the picture. However, it does not show up in posts.
Any suggestions?
469 (455 + .060") with the Edelbrock RAIV cam, Ported 6X-8 heads with 1.77" exhaust valves, 100 cc's, "0" decked block for 9.3:1 static CR, Eagle 1.65:1 roller rockers, Edelbrock RPM manifold and Edelbrock 750 carb., 1.75" x 3.0" Hedman Headers, 2.5" flowmaster exhaust system with "H" pipe and Dynamax super turbo mufflers. 200-4R with a Continental converter, 3.07:1 12 Bolt Saf-T-Trac |
Mine too,lol.. when u figure it out let me know
Hopefully someone will let us know. Good luck with that new motor. It sounded great in the video. Those tires look too narrow for that power...
469 (455 + .060") with the Edelbrock RAIV cam, Ported 6X-8 heads with 1.77" exhaust valves, 100 cc's, "0" decked block for 9.3:1 static CR, Eagle 1.65:1 roller rockers, Edelbrock RPM manifold and Edelbrock 750 carb., 1.75" x 3.0" Hedman Headers, 2.5" flowmaster exhaust system with "H" pipe and Dynamax super turbo mufflers. 200-4R with a Continental converter, 3.07:1 12 Bolt Saf-T-Trac Last edited by GR8ONE68; 01-03-2009 at 09:07 PM. |
[IMG][/IMG]
like this? your pcs must be loaded on a photo site on the www i use photobucket once thats done,,reply to a thread and look at top,,theres a envelope looking icon called ''insert image on the photo site theres a image link to the photo,,,copy that to the''insert image'' box the coding for the image i posted above looks like this but has a [ at the beginning of the pic and a ] at the end ---]IMG]http://i39.photobucket.com/albums/e152/wytnyt123/img391.jpg[/IMG[ the above brackets are reversed to show it to you and not load the pic same procedure works for signature pics too if more help is needed just pm me,,,be glad to help
aaaargh Last edited by wytnyt; 01-04-2009 at 09:15 PM. |
here is a couple pics showing the steps
sorry for the double pic,i run dual monitors [IMG][/IMG] [IMG][/IMG]
aaaargh |
testing
"No you fool, we're following orders. We were told to comb the desert so we're combing it." |
Thanks,
It worked. Kevin
test
keeps saying invalid file!!
Where is it saying invalid file? What screen are you on when it gives you that message?
GR8ONE68 got it to work using wytnyt's method. I'm still trying to figure out why it doesn't seem to be working with the uploaded signature picture in the UserCP. Steve
I was originally trying to do it through the upload on the user control panel. I could see it in the control panel, however, it would not show up on my posts. I created a Photo Bucket account, uploaded the picture, copied the address of the picture and pasted it into the signature as WYTNYT suggested and it worked.
Yea I have a photobucket account and tried it that way.. On the creen where it has the url and the save buttons thats when i get the invalid file thing... I copy it and paste it and then do u hit upload again? or just save?
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's Last edited by grandville455; 01-06-2009 at 03:25 PM. |
I deleted the picture that I had uploaded. I put the url in the brackets, and hit save.
still not working!! grrr
test
this is what i am inserting! why doesnt it work.... i pasted it in the message and it worked but not when i paste it into the url for the sig..
I just added a pic to mine. I used the "upload image from your computer" option. Note the size limitation.
It threw me at first too because like GR8ONE68 said, it shows in the CP, but not in your messages. You have to click "insert signature picture" which inserts the code.
Mine doesnt show me that insert signature? all it says is delete current image
Edit: After doing some experimenting, it appeares that the upload option will resize the image for you. I did notice however, that using WYTNYT's method I can add a larger image. Do you see your image like above just without the "insert" link?
Grandville455:
It looks like you are almost there. I see that you managed to get the picture uploaded as your signature picture. From there you should just need to click the text next to the picture that says "Insert Signature Picture". You said above that you didn't see that link. If that is true and you still don't see the link, you can add it manually to your signature field a little higher on the screen. Here is the text you need to add somewhere in the signature field: [ SIGPIC][/ SIGPIC] Except I pit a space in front of the 2 S's so that is displays so you can see it. You will need to remove the spaces in front of the S's. Steve
