'62 4cyl/auto Crank Seal
Anyone ever try replacing the factory rope with a 2pc BOP viton seal with the 4cyl engine still in car on tempest?
- can you get the oil pan off in car? - if not, to make room, can you jack up the engine a few inches with the torquetube still attached? Or will that risk cracking it? - if engine needs to come out, what are best 4cyl anchor balance points for the chain sling? Back of head/ front of head 3/8 bolts? |
here is how we hung it
Chris,too big file,will email.Tom
Best to pull the motor. Use the new BOP 1 piece seal.
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
2X on the one OC.Tom
Thanks. Do you need to fully remove the crank for the 1pc BOP seal, or can you get it in just lifting the crank a little?
I have the 2pc seal (new in package) and it does not flex at all. |
Chris,im 50/50 with the 2pc BOP seal.Im 100% with the 1 pc BOP and the Best gasket rope seal.The 1 pc seal is pretty much a 2 man job and the crank needs to be more than just lifted IMO.Tom
Thanks guys, will try my chances with the 2pc seal because already have it.
might as well,the engines are like a yoyo,they go down as easy as they go up!Never have time to do it right but always have time to do it over!You MIGHT get lucky!Tom
