Old 12-09-2021, 08:33 PM
many birds many birds is offline
Default Speedmaster heads
So…I bought a set of these during the Black Friday sale. Just got them delivered. What all should I be looking for on these before bolting them on the engine? These are the assembled flat tapper version. I’ve never used aluminum heads before—does any of the hardware need to be changed or can I just pull the stuff from my old stock heads.
Old 12-09-2021, 09:02 PM
Mike Davis's Avatar
You need the correct pushrod guide plates for the Speedmaster or Eheads. You also need a set of ARP head bolts or studs for E-heads.
Use the Felpro 1016 head gaskets as well.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 12-09-2021, 09:17 PM
tom s tom s is online now
Im having my shop check out the valve job,guide clearance,spring pressure open and closed and avail lift before I take a chance on bolting them one.Tom
Old 12-09-2021, 09:42 PM
gobrdgo gobrdgo is offline
I got mine bare. There’s some obvious core shift related material that could use some attention from my perspective. Your head guy will surely see it and be able to remedy for little time. I’m not saying it’s port work needed more blending the sharp machining lines.
The Following User Says Thank You to gobrdgo For This Useful Post:
Old 12-09-2021, 09:44 PM
Default One more
One more pic
Old 12-09-2021, 09:45 PM
One more try. Embarrassing myself trying to post pics
Old 12-09-2021, 09:54 PM
steve25 steve25 is online now
That size lip in the exh port below the seat incert is beyond horrendous!!
Old 12-09-2021, 10:28 PM
I’ve only picked up a little bit of what you’ve tried to teach me but yeah there’s a lot of low hanging fruit in the ports.
Old 12-09-2021, 11:17 PM
I’m curious to see what you find.
Old 12-10-2021, 12:42 AM
blueghoast's Avatar
You can get guids and studs from speedmaster.
Some good cleaning and there ready to go.
I would do a little blending in certain area's
The assembled heads are more finished then the bare heads.
GT
Old 12-10-2021, 01:11 AM
Mike Davis's Avatar
GT
Agree, I got a set complete and they actually looked good. Valves were seated etc. I did disassemble and clean the ports and bowls up some.
Flowed 302 with very little work.
The Following User Says Thank You to Mike Davis For This Useful Post:
Old 12-10-2021, 03:14 PM
NeighborsComplaint's Avatar
That's "horrendous" for an $1100 set of heads! lol.
If they made an 87cc version, they would already be on my car!
Triple Black 1971 GTO
Old 12-10-2021, 03:35 PM
I will double down on my horrendous comment, how’s this?
That also shows how much casting core shift those heads have, or can have!
I have never seen that much shift in any aftermarket head!
Are you folks expanding that picture up to fully see what I am commenting on?
Old 12-10-2021, 04:01 PM
Mike Davis's Avatar
Steve, The heads I got had very little casting shift. They actually looked better than my first set of E Heads.
I have only seen about 3 sets of the Speedmasters and they all looked ok.
Old 12-10-2021, 09:07 PM
Formulas Formulas is offline
Perhaps the bare heads are a little on the unfinished side or a set slipped through missing a process step
That does look like as cast port with zero transition work to the cut to accommodate the seat insert
I dont see how that particular exhaust port could flow more than stock
I couldn't just slap those on in good conscious I would at least do a heavy blend job
Old 12-10-2021, 10:47 PM
grandam1979 grandam1979 is offline
The out of the box set I have on my sons car perform very well. I was going to clean them up but everybody was talking how bad they are so I had to do it to know for myself. With that said they do have some areas entering the ports that really could use some help to make better. Engine is what I would consider a street engine and I did not dyno it but I think it’s over 500 from a 469. Car is well into the 10’s at over 3000# I got another set this year I’m going to do some clean up on and see how it runs next summer.
Old 12-11-2021, 02:59 AM
Bare heads are not fully machined or finished.
Old 12-11-2021, 12:29 PM
72projectbird's Avatar
Iirc they are cast in Australia, and finished machined in China. Normally I'd expect core shift like that from something cast in China, but apparently the Aussies are up to the same things.
Still, I'd take a shot at them if they made an 87cc version, but I guess they don't want half of their customer base.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 12-11-2021, 02:04 PM
You guys are funny I have a 68 400 block here in the shop that has really bad core shift. I have seen Intakes with castings so bad you could cut yourself picking them up stop kicking a dead dog.
Old 12-11-2021, 02:05 PM
70 bird's Avatar
70 bird 70 bird is offline
Do the push rod holes have to be clearanced for 1.65 rockers?
