Old 07-31-2022, 04:43 PM
cnc's Avatar
cnc cnc is offline
Default Grd wire from heater core box to firewall????
I'm in the reassembly process after a few years finally.....put new heater core in and re installing into the car.....is there a grd wire from the case under the hood to the firewall....thought I took enough pics before disassembly but don't see anything for this area....cars a 73 no A/C....thanks Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 07-31-2022, 06:45 PM
Formulabruce's Avatar
There is a ground, with a star washer end ( external)
That goes in a hole below box and towards the valve cover. I think it goes to the head on back side of it passenger side.will look for pics later.
Old 07-31-2022, 07:44 PM
The ground strap attaches to the rear of the passenger side cylinder head. These pictures are of my 71 Firebird.
ID:	595455   Click image for larger version
Old 08-01-2022, 02:15 AM
hiyabradHO hiyabradHO is offline
How many ground connections are there for ‘71 T/A? And where are the locations? Pics would be very helpful, if possible. Thank you.
Old 08-01-2022, 07:34 AM
cnc's Avatar
cnc cnc is offline
Ok that's what I have and the heavy black wire is for the fan right...
Old 08-01-2022, 03:45 PM
Yes.
Originally Posted by cnc View Post
...and the heavy black wire is for the fan right...
