Just as an observation: With the Cal-Tracs and other suspension mods, many of the quickest Stockers are using wheelie bars to keep the front end down some.
So, it doesn't appear that the extra weight of the aftermarket blocks makes any significant difference. Scott Burton has the heavy block & still NEEDS the wheelie bar. From some of the wheelies Randi Lyn has pulled, looks like maybe she could use a wheelie bar. Last edited by ponyakr; 04-16-2018 at 12:02 PM. |
Block lightening will allow you to put weight where it is desired at that track on that day.
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Remember , that Randi Lyn's car is very Fast & has the best of everything & she is a Very Good Driver !!! The car is a Show piece and they are good people ... Back about 5-6 years ago they let Pontiac's use 750+800 CFM GM side -inlet , because you couldn't find good cores anymore !!! But only the Ram-Air engine can use the 71 Fast carb in Stock !!! That is the first thing they check when going thru Tech ??? The block has an advantage went you start getting above 6,500 RPM in Stock , bye the way Chevys, Ford & Mopar have had them for years !!! You are right Stock & S/S aren't cheap , but you don't need the best of everything to Win or have fun ?
Really depends on what your budget is or you can afford ? Not everyone has an enclose trailer , I still use an open trailer because of the cost & I want to Race !!! We all have different Wants & Needs ??? So it can be done and budget Races are doing everyday & having Fun !!!! |
However, if you open restriction in vacuum can AND add a fine adjustment valve (quality filter "bubble" regulator from aquarium supply store) you can then tune the opening rate for no bog or any rate you want and keep flap tension spring at a minimum tension. |
Thanks !
Dave, THANKS for posting ! We really appreciate your input. You've been there & done it, whereas my experience is VERY limited.
"...only the Ram-Air engine can use the 71 Fast carb in Stock !!!" So, are you referring to the one without the outer booster rings ? And are we talkin about just the 455HO with RA ? About your '77 Bird record holder: Did you always run a 400 or did you run a 350 or both ? Did you try both the 180hp & the 200hp 400 engines ? Are you gonna run the Lemans & your son run the Bird this year ? Do both cars run the same engine combo ? Please feel free to share anything that will help us to know more about Stock class racing. Thanks again ! Last edited by ponyakr; 04-20-2018 at 10:50 AM. |
Randi Lyn just cut a .012 light & ran a 10.403 on her 10.40 dial. That package will win most rounds.
https://www.dragracecentral.com/DRCS...er=30#indextop |
Nice!
