Outside of the very quick-ratio steering boxes that seem to be what most guys install as an upgrade, what other years/models of steering boxes can be used to provide a slightly quicker ratio without going to the super quick boxes?
Mike |
Mike |
Hi Mike,
If your talking about power steering boxes, I have used 1970-1972 Olds Cutlass boxes in '69 and older cars. '67 boxes are 17:1 constant ratio where as the '70 Olds boxes are 12:1(I think)Variable ratio. You can usually get these at most salvage yards for a song(under $50). Good alternative to the real fast boxes. You can notice a difference in the steering response. Hope this helps. Steven
1967 Pontiac GTO 1965 Olds Cutlass 2014 Ford Mustang ----------------------------------- GTO-The Great One for 1967 ----------------------------------- |
Steve,
Thanks....that's exactly the info I'm looking for....and yes it is for power steering boxes. Do these years have any metric threading and/or glitches with the rag joint or are they pretty much a direct swap?
Mike |
Mike,
Metric fittings came about '76,'77 or '78(can't remember exactly).I like to stay around '70-'72,'73.They still have the flared fitting and the rag joint coupling that is the same as our cars. Early TransAm boxes ('71-'73 or '74) are also good choices;If you can find one! After you get a new box in,go and get the alignment changed. Try to get as much positive caster as your car will allow. I got about 1.5 degrees positive in mine now and the handling with the faster steering was fantastic!!! Find a good alignment man that will work with you in this. Steven
Your steering box probably is probably 4 1/2 turns left to right. Most all 68-72 GTO's used boxes that were 3 1/2 turns. The quick ratio's being sold are around 2 3/4 turns. Direct bolt in on all GTO power steering boxes.
--------------------------- Fool Around, Get Hurt, Don't come Crying to me. |
