Old 04-17-2002, 08:07 PM
Bob Brogan Bob Brogan is offline
They are 16,and I look them up. Thank you
[ April 17, 2002, 08:52 PM: Message edited by: Bob Brogan ]
Old 04-17-2002, 11:18 PM
Gooatee's Avatar
Gooatee Gooatee is offline
Glad you found them!
Old 04-17-2002, 11:21 PM
Gooatee's Avatar
Those are the same heads I have on my 400 and they work really well! They are high compression heads!
Old 04-18-2002, 10:29 PM
Are they ram air 3 heads?
Old 04-18-2002, 10:47 PM
Gooatee's Avatar
I do believe they are! They are a good head as they have big valves, screw in studs w/guide plates, and high compression! Send them out to a known Pontiac head guru, ie: Butler, Indian Adventures, Pontiac Dude, SD Performance and have them ported and you will have yourself a great set of heads!!!!
Old 04-19-2002, 11:07 AM
Sorry,but these are not Ram Air heads.
They also are not big valve heads,they are small valve,pressed in studs.
They made 2 casting number 16 heads.
The ealier 16's were big valve,screw in studs.
The 16's on you're YD engine is the small valve 1.96/1.66
Old 04-19-2002, 11:32 AM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
johnta1 is correct, actually they made 3 casting 16 heads with the third being the 73-74 SD455 round port head.
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
Old 04-19-2002, 07:18 PM
You are right,they are the small 1.96 intake valve heads,pressed in studs.What do you recomed I do to get all the preformance that I can out of these heads?I want to put roller rockers on them,do I need to replace the pressed in rocker studs?They are 2 brl heads,will the intake ports match a 4 brl intake?or would they need port matched?
Old 05-11-2002, 06:17 PM
Yes it would be wise to put screw in studs in them.
The intake ports will match.
IMHO it would be cheaper to find some 6X's or other 4 bbl head and use them than do the work on the 16's.
