Old 04-29-2020, 11:01 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Default Square vs round trailing arms
I’m looking at suspension upgrades for my 67 GTO. I need adjustable upper rear control arms to correct pinion angle and plan to upgrade the lower arms right away. I’ll be running a rear sway bar and I’m wondering if the torsional twisting will cause issues on round lower control arms in the long run? Im looking at UMI pieces and between their round lowers or fully boxed lowers.
https://www.umiperformance.com/home/...trol-arms-kit/
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 04-29-2020, 11:12 PM
leeklm's Avatar
leeklm leeklm is offline
I ran the UMI adjustable roto joint upper arms in my 66, nice product. For lowers I just boxed in the factory arms and installed poly bushings. That setup worked well and eliminated any wheel hop.
Sent from my SM-G965U using Tapatalk
Old 04-29-2020, 11:27 PM
67gtospud's Avatar
My lowers are currently boxed but I’d prefer to replace them vs continue running 50+ year old suspension components. My goal is to replace and upgrade my entire suspension over the next few years.
Old 04-30-2020, 05:15 AM
Geoff Geoff is online now
Round section will twist less.
Old 04-30-2020, 11:57 AM
Chris65LeMans's Avatar
What are you going to use the car for? It'll matter less on a car you plan to cruise than on a drag car that you're trying to get into the 9's.
I have UMI front arms on mine. When I replaced my suspension, I don't think that UMI offered the squared ones for the rear, so I bought a set from PMT Fabrication. I was coming off of what I thought was a suspension failure at 65 mph (later determined to be a rear end failure), so I felt more comfortable with the square ones that "looked beefier."
Old 04-30-2020, 12:09 PM
67gtospud's Avatar
Car is a weekend cruiser with some spirited driving. Rarely (if ever) will see the drag strip. I put on 4-6k miles a year. If round will hold up no issue then I see no reason to spend the additional $130 on the beefier square ones for my intended purpose.
Old 04-30-2020, 05:04 PM
David Jones's Avatar
I’ve had round BMR Fabrication rear adjustable uppers and lowers and their 7/8“ sway bar on my car since 2002. No issues that I’m aware of.
Old 05-01-2020, 08:56 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I have the round UMI rear lowers with no sway bar. Very nice quality and I got the black ones. They look pretty inconspicuous and were cheaper than stock boxed. Supposedly stronger according to UMI. If you have stock boxed you could just replace bushings.
Chris D
Old 05-12-2020, 03:57 PM
DogMeister's Avatar
DogMeister DogMeister is offline
I put the round UMI lowers on my '67 with the UMI anti-sway bar. Nice combo, black looks cool, and really leveled out the ride. I take it on the Tail of the Dragon every year and what a difference.
461 Stroker Built by Me -
Old 05-16-2020, 12:58 AM
64speed's Avatar
64speed 64speed is offline
I have the UMI round non adjustable top and bottom with swaybar. Rear suspension is stiff as a ministers peter
Old 05-18-2020, 12:11 PM
RA66GTO's Avatar
RA66GTO RA66GTO is offline
We started years ago with a set of swap meet sourced adjustable Hotchkis Adjustable Uppers and have progressed to the Boxed UMI Lowers and Hellwig Bar.
Car is driven an average of 1,000 miles a month and is 'thrashed' at auto-crosses and through the mountains.
https://www.hotchkis.net/product/196...&md=1089&sm=20
https://www.umiperformance.com/home/...boxed-premium/
https://www.hellwigproducts.com/prod...artnumber=5800
1966 GTO Resto-Mod. 2nd owner California car, factory Air, Power Windows, Holley Sniper Quadrajet, MSD Dual-Sync, Gearstar 200-4R, Yank 2400 Stall Converter, HGM Compushift Mini, Heidt's Tall Spindle, UMI Control Arms, Hellwig sway bars, CPP Big Brakes, AR Torque Thrust M, Continental Extreme Contact DW
