1967 Restoration Parts-The Entire Updated List 3/9/2022 <<Many Recent Changes>>
Please Note:
Orders above $600 will be split into two lots and paid separately if paid by PayPal due to new IRS reporting requirements (Thanks to Uncle Joe). Fuel and brake lines will not qualify for free shipping. Feel free to inquire with your needs. All parts are NEW unless noted otherwise. Bear in mind these are mostly New REPRODUCTION parts. Very few of these parts are GM NOS. Most were purchased from Ames Performance, OPG., etc. I will consider offers for the lot and make any necessary adjustments to the offer price if some items are sold in the meantime. I will consider free or shared shipping for large orders or pickup here at no cost for any size purchase (NH). Bucket Seat Bracket Set $25 Door Panel Fastener $0.50 Door Panel Fastener Grommet $0.50 Door Top Inside (Beltline) Moldings $35 Rear Quarter Inside (Beltline) Moldings $35 64-67 Door Quarter Watersheds (Paper) $18 Kick Panel Insulation $5 Under Seat Drain Plug $3 Kick Panel Vent Control Cable w/Knob $27 (have 2) Kick Panel Control Cable Clip $1 "Speaker" Bezel for Radio $4 Set of heater control cables $55 Dome Lamp Terminals $3 Visor Bushing kit $10 Headlight Bezels (R&L Pair) $170 Exterior Door Handles $70 Right Door Latch $65 Door Striker $8 (have 2) Window Crank/Door Handle Retainer Clip $0.50 (have 6) Aftermarket window regulator (r/f) $60 Aftermarket window regulator (l/f) $60 Vent Window Crank (R&L Pair) $50 Screw-in Replacement Windshield Trim Clip Studs Set $4 Gas Cap (1964-Vented) $30 Gas Cap (1970 Not Vented) $15 (Not knurled edge type, has 2 tabs) Fuel Tank Straps (aftermarket, slight surface rust) $30 Aftermarket Front Stereo Speaker w/ Brackets $25 Fuel Pump (w/vent) (Cardone) $42 Fuel Pump to Carb Line (Qjet) $20 Front to Rear Fuel Line (5/16") $50 Front to Rear Fuel Vent Line $50 Fuel Line Clip Set for 5/16" Line w/Vapor Line $10 Fuel Line Clip Set for 3/8" Line w/Vapor Line $10 Power Steering Pump Mounting Bracket (steel, pump-to-aluminum bracket) $20 Throttle Cable $50 Intake Manifold Gasket Set (Felpro) $20 68-77 Valley Pan Gasket $5 D Port Metal Exhaust Manifold Gasket Set $10 Reman Starter Delco 323-256 (1893 732 GM) $90 Reman Starter Solenoid Delco D981 (1114458 GM) $45 Starter Mounting Bolt $5 (have 2) 1967-70 Q-jet Throttle Shaft & Bracket $60 Carb to Manifold Vacuum Stud $10 67-70 Q-jet Idle Mixture Screw $6 (have 2) Q-jet Carburetor Float $6 Q-jet Carburetor Mounting Gasket to 1969 $3 Q-jet Carburetor Mounting Gasket 1968-74 $5 PCV Valve $5 Reproduction Plug Wire Set (dated 4-Q-66) $70 The following Delco parts: Universal Plug Wire Set (12043774) $30 Distributor Cap (12363081) $10 Condensers (12338665) $8 (have 3) Contact Sets (12338660) $17 (have 3) Rotors (12338671) $5 (have 3) Distributor Hold Down $12 Standard Valve Cover Gasket (Rubber) $20 (pair) Outer Dipstick Tube $25 Oil Pan Drain Plug $3 Oil Pan Gasket Set $15 Timing Cover Bolt & Stud Kit $10 Cylinder Head to Block Alignment Pin $4 (have 4) V-8 Head Gasket $15 (have 2) Fuel Pump Eccentric (light surface rust) $35 Timing Cover Gasket Set $22 Engine Freeze Plug Set (Steel) $11 Cylinder Head Freeze Plug Set $6 Black Nylon Compartment Strap $1.50 (have 5) A/C Vacuum Hose Check Valve $8 2" Fan Spacer (GM) $22 Radiator Cap $13 Accelerator Pad Pin $2 Accelerator Pad Spring $3 Heater Hose Nipple (Head) $20 Clutch Rod Seal $8 Clutch Rod Seal Retainer $12 Tail shaft to Hurst 4 Speed Shifter Adapter Plate $25 Shift Cable Floor Pan Grommet $5 Transmission Crossmember Insulator Brackets (pair) $24 Muncie 4-speed Gasket Set $20 Parking Brake Ratchet $70 Front Parking Brake Cable (64-67 M/T & Powerglide) $38 Rear Parking Brake Cable (64-77) $38 (have 2) Mickey Mouse Brake Cable Clip $1 (have 4) Front Brake Line Set (Std. Drum Brakes, Steel) $50 Rear Brake Line Set (Steel) $20 Front Flex Brake Line Clip $1 (have 2) Front Drum Brake Flex Line $17 (have 2) Rear Brake Flex Line $20 Disk Brake Distribution Valve Bracket $15 68-72 Rear Brake Flex Hose Bracket $20 Rear Wheel Bearing $30 (have 2) Rear Wheel Seal $8 (have 2) Front Wheel Bearing Kit (Drum) $70 Axle Flange Gasket $1.50 (have 2) Rear Axle Lubricant 80W-90 GM (23 oz) $12 Front Wheel Cylinder (Left) $20 Front Wheel Cylinder (Right) $20 Rear Wheel Cylinder R/L $15 (have 6) Front Drum Brake Spring Kit (64-72) $10 Rear Drum brake Spring Kit (46-75) $10 Rear Brake Shoe Guide $1 (have 4) Parking Brake Spacer Bar $8 (have 2) Left Front Brake Adjuster Kit (64-72) $12 Right Front Brake Adjuster Kit (64-72) $12 Left Rear Brake Adjuster Kit (64-72) $12 Right Rear Brake Adjuster Kit (64-72) $12 Upper Ball Joint $22 (have 2) Lower Ball Joint $27 (have 2) Inner Tie Rod $65 (have 2) Outer Tie Rod $45 (have 2) Tie Rod Adjustment Sleeve $10 (have 2) Steering Center Shaft $100 Steering Idler Arm $40 Power steering pressure hose $25 Upper Control Arm Bumper $5 (have 2) Lower Control Arm Bumper $5 (have 2) Axle Bumper (pair) $15 Sway Bar Bushing, Stock Bar (pair) $8 Sway Bar Bushing Retainer (pair) $10 Sway Bar Link Kit $12 64-68 Front Drum Brake Wheel Stud $2 (have 5) 65-77 Rear Wheel Stud $1.50 (have 5) PMD Rally II Center Lucite (Red) $12 Rear Spring Insulators $6 Decal-Turquoise GM Mark Of Excellence (foil) $4 (have 2) Decal-Air Shock Instructions $4 Decal- 421-Tri-Power 425 HP $4 (have 2) Antenna Lead Firewall Grommet $15 Gas Pedal Rod Support (Plastic) $21 10-bolt Rear End Cover Gasket $6.50 (have 2) Axle Flange Gasket $1.50 (have 2) Instrument Cluster Lens (Rally w/Tach needle) $30 Instrument Cluster Lens (Rally for Oil/Water Gauges) $12
Just an old goat cruisin' in an old Goat........LIFE IS GOOD!! |
