Old 10-01-2005, 04:52 PM
Tom Vaught's Avatar
Boost Engineer
The pics you posted are of known engineering exercises and have been written up in several mags over the years. I spoke to several of the engines in some of my earlier posts in this topic. These are the engines that Tom Nell was aware of too.
The TRUE HEMI 427 PONTIAC engine that was the engine in question (with the head bolts that go to the mains area) has still not been proven to be more than a engineer's dream.
Tom V.
  #62
Old 10-02-2005, 11:11 PM
Dragncar Dragncar is online now
Baron,that is what I am trying to do.Could be pretty close,keep your fingers crossed.That 303 is chump change compaired to that 427 SOHC Hemi.Trying to shed some light.
  #63
Old 10-03-2005, 09:26 AM
Steve Hoog's Avatar
Steve Hoog Steve Hoog is offline
formerly Steved400
Send a message via Yahoo to Steve Hoog
What is this 70's magazine everyone is referring to? Why can't some one post it?
The Following User Says Thank You to Steve Hoog For This Useful Post:
  #64
Old 10-03-2005, 09:43 AM
Stuart's Avatar
Stuart Stuart is offline
They're talking about a 1970 issue of Hot Rod magazine; the front cover had a picture of a proposed 427ci, overhead cam Pontiac engine. It was pretty radical for the time. The article indicated it was only an engineering exercise and was not a running engine, but on the other hand you can't believe everything that was written in the car mags back then either, which is part of the big controversy here.
  #65
Old 10-03-2005, 09:47 AM
Steve Hoog's Avatar
formerly Steved400
Which month is it, and I'll try to buy it on Ebay and post it in here.
  #66
Old 10-03-2005, 10:48 AM
Stuart's Avatar
It was the October 1970 issue. There's a copy on ebay right now, here's the cover shot.
Ebay Link
  #67
Old 10-03-2005, 10:52 AM
Steve Hoog's Avatar
formerly Steved400
I'm on it Stuart, thank you.
If I win it, I'll post it as soon as I get it.
  #68
Old 10-03-2005, 04:40 PM
Stuart's Avatar
If you want a copy of the magazine for yourself go ahead, but if all you're looking for is that specific article, I have a copy of the magazine myself and I could scan it in.
  #69
Old 10-03-2005, 05:01 PM
Steve Hoog's Avatar
formerly Steved400
Both sounds good to me, I want to read it for myself and post it for others too. Be nice to have a copy of the magazine for my collection also.
  #70
Old 10-03-2005, 06:04 PM
Tom Vaught's Avatar
Boost Engineer
Like I said before TRULY AN OUTSTANDING ENGINE DESIGN that never made it into production until Ford did it (in some respects) on the 4.6L Modular engine.
Similarities:
The extra wide valve cover design.
The cover for the spark plug wires.
The front mounted oil pump, (Ford's is crank driven)
The "easy to remove" front cover to get access to the cam drive.
Fuel Injection (Mechanical on the Pontiac, EFI on the Ford).
Long head bolts going well into the block. (Ford's are over 9" long)
A very strong for its weight engine block. (A modular 4.6L aluminum block as run as fast as 6.70s in the quarter).
Man, I wish Pontiac would have built that thing vs the Ford guys!
Tom V.
  #71
Old 10-03-2005, 10:04 PM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
A couple of pix from the 1970 Hot Rod article:
The rods look familiar...
http://www.pontiacpower.org/
  #72
Old 10-03-2005, 10:53 PM
Tom Vaught's Avatar
Boost Engineer
I will try and look for a cut-away of the SOHC Ford 4.6L engine.
I firmly believe Ford copied the above engine in many ways.
The picture shows the Ram Air V (Ford Tunnel Port) type connecting rod which was much later than the previous programs McKeller did.
Tom V.
  #73
Old 10-03-2005, 11:57 PM
O-M-G ... Nice work there fiedlerh ! Now maybe a call to Knafel, or the driver of the 70 Tin Indian, or whoever bought car from Knafel, and see if any of them have recollection to these tunnel port hemi OHC heads and etc... maybe it became more than a designers dream mock up.
Good Luck Dragn and Steve
Groovy Sh!t
  #74
Old 10-04-2005, 01:13 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Tom V.
Tom-
The article talked about "electronic metered" injection on the Pontiac.
The outboard headbolts on the Pontiac were 9/16" dia. by 14" long, tying EVERYTHING from the cam stands down to the main caps/girdle together!
Tom- Do you know if any volume-production engine ever used die-cast blocks and heads, like this Pontiac intended to?
Everybody- Has anyone ever heard anything of the present whereabouts of Huldi Aldikacti "father of the Fiero"? He was head of the Advance Design group when the article was written. How about Steve Malone, who was Pontiac's Chief Engineer at the time? Or Feature Editor Steve Kelly, author of the article?
Edit 10/5/05: Tom, my question was answered by reading Ray Brock's Publisher's Memo in that same Oct '70 issue of Hot Rod. He called attention to the die-cast alloy block of the new Vega 4 cylinder.
  #75
Old 10-04-2005, 01:34 AM
Steve Hoog's Avatar
formerly Steved400
Baron
That would be Arlen Vanke, but I have no way to contact him. I wouldn't even guess if he was the one that started the Goatfinder on the suggestion in the first place, although possible.
I know these aren't what this thread is about, but I ran across them while looking and I think they are cool. M/T Hemi:
ID:	28907   Click image for larger version
  #76
Old 10-04-2005, 05:35 PM
Stuart's Avatar
Here's the Hot Rod article.
ID:	28941   Click image for larger version
ID:	28942   Click image for larger version
ID:	28943   Click image for larger version
ID:	28944   Click image for larger version
  #77
Old 10-04-2005, 11:26 PM
fiedlerh's Avatar
Wasn't the Ford/Yamaha SHO engines die cast by Mercury Marine?
What about the VW and similar engines?
  #78
Old 10-05-2005, 12:21 AM
Thanks. I am merely curious about whether die-casting alloy engine parts has turned out to be practical, i.e. cheap enough. I just edited my question, since I learned that the Vega 4-cylinder block was die-cast.
I used to borrow a '53 VW, in which I think the parts were sand-cast, but not sure.
  #79
Old 10-05-2005, 01:28 AM
Steve Hoog's Avatar
formerly Steved400
Stuart
Thank you.
  #80
Old 10-08-2005, 07:40 PM
Steve Hoog's Avatar
formerly Steved400
Stuart
Got it, thanks for the lead.
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWN:IT
Steve
