Old 09-02-2010, 01:21 AM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Default Aluminum Ram Air Vs
Just unboxed a set V heads from McCarty Racing. Very interesting pieces. These will change the complexion of the Pontiac racing community...
These arrived very well packaged and came with seats and guides installed.
Observations as delivered:
Outward appearance - Casting quality is very good with very, very minimal flaws and no porosity noted on machined surfaces.
Machine work also appears to be of very good quality with nice finish work. Note at this point I have not actually bolted them on a block yet.
Intake ports measured just a tick over 2.15" diameter :-)
Intake flange is raised just a tick over .65" from the valley cover edge :-)
Intake throat dia is 1.935"; Exhaust throat dia is 1.489" :-)
Combustion chambers measured +4.270" across
Valve cover rail is angled 14 degrees compared to the stock Pontiac 20 degree angle as measured from the deck. It appears the outer portion of the valve cover rail is approximately .390" higher than an uncut E head...FYI just in case you want to run your power brake booster. :-)
Two oil drain back holes positioned adjacent to what would be #2 and #4 (or #3 and #5) exhaust valve spring pocket.
No pushrod holes drilled for either exhaust or intake.
Port work appears very nicely crafted with generous widths and short turn radiuses on both intake and exhaust. :-)
More to follow on flow volumes and miscellaneous
Jim
ID:	217360   Click image for larger version
ID:	217361   Click image for larger version
ID:	217362   Click image for larger version
ID:	217363   Click image for larger version
Old 09-02-2010, 01:23 AM
Default More pics
More
ID:	217365   Click image for larger version
ID:	217366   Click image for larger version
ID:	217367   Click image for larger version
ID:	217368   Click image for larger version
Old 09-02-2010, 01:38 AM
Default Water holes
Here are the water hole location and sizes compared to an original GM Victor gasket part no. 488474 (455 cid)
ID:	217371   Click image for larger version
ID:	217373   Click image for larger version
ID:	217374   Click image for larger version
Old 09-02-2010, 01:58 AM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
thats awesome... very cool to see lynns creation coming to life before our eyes
1972 Pontiac LeMans
Thanks to
Fuelab Digital Fuel Delivery
Quarter-Max Chassis and Racing Components
Old 09-02-2010, 06:41 AM
rad400 rad400 is offline
Great looking heads, should make one beast of a race car. Keep us posted.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 09-02-2010, 07:40 AM
spartazoo's Avatar
spartazoo spartazoo is offline
Hey...I thought porn was not allowed on the site. Man those are sexy!
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
1966 GTO Hardtop - PS 14.84 @ 97mph
Old 09-02-2010, 10:25 AM
Brian Baker's Avatar
I think this marks the first time anyone has ever fully documented the release of an aftermarket head for a Pontiac. We never even got this much information when the Edelbrocks first came out. Good job.
Old 09-02-2010, 11:00 AM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Wish I were a bit closer, Jim. Would love to see them in person.
Thanks for the pics!
Regards,
"455HO" Lloyd
Old 09-02-2010, 11:36 AM
Steve Barcak's Avatar
Looks nice Jim. Keep us posted on your progress with them. What are your plans with these? intake, etc.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 09-02-2010, 12:02 PM
cgeise's Avatar
cgeise cgeise is offline
Maybe Im missing something but -- why no push rod holes? Dont the intakes go thru the port and need special attention ? What valve size are these going to be built for ?
Old 09-02-2010, 12:07 PM
R 70 Judge's Avatar
Very cool!
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 09-02-2010, 02:25 PM
tom s tom s is offline
those are my heads and will be put on my alu V block and will go in my 69 Judge.Am building toward 10.25 CR 236-242 cam with 660ish lift and my custom ford-V single plane single 4 intake Jim did for me.Nothing special.Tom
Old 09-02-2010, 02:27 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Wow, that's going to be something to see.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 09-02-2010, 07:12 PM
Aluminum V parts are very cool and I am humbled by the opportunity to work them.
Brian,
If I was in the market for a set of heads I would be interested in some of the basic dimensions...seems simple enough to provide detailed data for those interested.
cgeise,
We will be installing the pushrod openings/tubes here. Valve sizes will be close to originals 2.19/1.73.
Jim
Old 09-03-2010, 09:35 AM
bobzdar bobzdar is offline
What's the min. chamber size?
Old 09-03-2010, 10:45 AM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Thumbs up
Very Nice looking castings Indeed. I really like the width at the short turn. Top notch castings for sure. Great job Lynn. Jim keep us posted on flow #'s as you progress with porting.
Old 09-03-2010, 11:32 PM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
69 GTO Judge with an alum RA V,nothing special yes right.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 09-04-2010, 12:14 AM
Recommend you ask Lynn about the minimum chamber volume design...not sure how much material exists for milling. I have not measured the chambers in these because we have not machined valve seats.
These measure a very consistent 2.088" width at the beginning of the shortturn. :-)
These are destined for a 4.120" bore so we are inclined to install a valve smaller than a 2.190". Valve are placed such that .133" is between an installed 2.190" intake and a 1.770" exhaust...so shrouding could be an issue on smaller bores.
2.190" + 1.770" + .133" = 4.093" across the valves.
Jim
Old 09-04-2010, 08:06 AM
GTOLou GTOLou is offline
Waaay cool. This is a pontiac head - that'll help sales alone. I've always said if someone recast a ramair IV head for the street in aluminum that was comparable to an ehead/ported ehead - it'd sell well.
Old 09-06-2010, 09:48 AM
I'm not sure I understand that statement - an ehead is basically an aluminum ramair IV head? Just buy a set of those and grind of the edelbrock script. Now a true repro ramair IV head might sell for those that want to class race or restore cars...
