Old 06-04-2016, 08:36 PM
mgarblik mgarblik is offline
Got it. Thanks.
  #42
Old 06-04-2016, 10:16 PM
Tom Vaught's Avatar
Boost Engineer
Replied again, Think all is good either way.
Tom V.
  #43
Old 06-04-2016, 10:38 PM
BILL BOWMAN1's Avatar
I am amazed how a modern top fueler can make a pass without locking up the motor without coolant.
  #44
Old 06-05-2016, 07:58 AM
taff2's Avatar
taff2 taff2 is offline
I'm assuming the Palbykin mod is the stepped area at the top of the bores for gas or solid rings to be inserted? Come on Tom, spit it out!
  #45
Old 06-05-2016, 08:19 AM
A great amount of cooling from oil and the air/fuel mix...to some minor degree air cooling.
The relatively short amount of time at full thermal load plays a big part in survival.
  #46
Old 06-05-2016, 08:23 AM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
taff, I had a set of those items in my hands 2 months ago, but I will not spill the beans!!!
Steve
  #47
Old 06-05-2016, 09:10 AM
Robert C.'s Avatar
Robert C. Robert C. is offline
These blocks are cast and then heat treaded in a very special way in a vacuum oven and vibrated for 9.5 hours then water quench to 32 degrees. This makes the aluminum denser. Very close to a extruded solid aluminum billet.
Deck height is 10.240
Bob C.
Quickest, Fastest, Best selling Pontiac Aftermarket Block IA II and Tiger Heads
Boss Bird Funny Car
Best pass to date 08/06/2016 6.027@231.64
Allpontiac Big Chief Aluminum Engine Block
http://www.AllPontiac.com
  #48
Old 06-05-2016, 09:17 AM
Robert C.'s Avatar
Guess who got this block?
Bob C.
Boss Bird Funny Car
  #49
Old 06-05-2016, 10:54 AM
Tom Vaught's Avatar
Boost Engineer
I suspect that the majority of the blocks will remain at the standard 10.240" deck height as it makes little sense to add a sealing provision if you have not been having head sealing issues in the past.
Yes, The Palbykin Mod was the ring that Marty and Tom Earhart came up with many years ago.
Tom V.
  #50
Old 06-05-2016, 11:07 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
"Street car" with no water cooling... Hmm.
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
  #51
Old 06-05-2016, 11:23 AM
Robert C.'s Avatar
No street car for a all out alcohol motor.
The water jacket Aluminum blocks are also very good race blocks.
J. V. Has won over 150 thousand with his aluminum IA II
Bob C.
Boss Bird Funny Car
  #52
Old 06-05-2016, 08:44 PM
Dragncar Dragncar is offline
Is making these blocks with skirted mains cost prohibitive ? Sure would be a lot cheaper for guys like 3fast to get one with LS/FE mains vs calling up LSM and paying through the nose.
Anyway, nice job All Pontiac. Works of art to guys like us.
  #53
Old 06-05-2016, 09:03 PM
I don't know the cost difference, but it would have to be substantial. These blocks are a big upgrade for us and a few others who don't need water in the block. To make a skirted block would mean new patterns for the bottom of the block, new cores, modifications to the core box or a new box. For the small numbers we are talking about a billet block may actually cost less. The block we have now required the REMOVAL of cooling cores, some other modifications to the existing cores but not a complete redesign. This made it more cost effective and much faster to have made. The additional heat treat and HIP process improves the density and elongation ability of the aluminum. Yes a skirted block would possibly be even a better deal but would in our situation also require thousands of additional dollars to change: 1. the current 2-piece oil pan would not fit a skirted block. 2. Our entire mag drive, oil pump, blower belt drive and fuel pump drive have been configured to fit a stock Pontiac front cover. All that would have to be changed and re-designed with a skirted block. 3. One of the final identifying features of this being a traditional Pontiac engine would be gone. Not denying it may be better. I am a big fan of the Ford FE engine. It's my second favorite after Pontiac and shares some design features. We are going to do our best to have this block take us where we want to go.
  #54
Old 06-05-2016, 09:26 PM
Way to go Bob C.
This solid aluminum block with the added stiffness-enhancing features is the most exciting development in Pontiac race blocks in a long time.
I can see others with ultra-high HP Pontiac builds grabbing one of these up, I'd bet Big Chief will be in line for one soon for the Crow Mod.
Best of luck to Eric, Mike and their crew, we're all very excited in the Pontiac racing community and and can't wait so see your performance with the new solid aluminum block.
Bart
  #55
Old 06-05-2016, 09:50 PM
Elarson's Avatar
Elarson Elarson is offline
A lot of folks in the nitro community were sure that our iron block would die a quick death. The thinking is that the flexibility of aluminum is needed to absorb the extreme loads. The iron IA2 has taken a beating and proven them wrong. But now it's time to take the next step. Replaceable sleeves will make service easier and the weight savings will be important. And we feel that the overall strength will be even better than what we have now.
This block will work for anyone running methanol or nitro (who don't need water cooling). The key to the power of a nitro engine is injecting liquid fuel instead of vapor, allowing a lot more fuel to be stuffed in. Liquid won't burn....it needs to vaporize in the cylinder. And vaporization absorbs a lot of heat, hence eliminating the need for cooling water.
Eric
  #56
Old 06-06-2016, 09:08 AM
Robert C.'s Avatar
Way to go Bob C.
Bart
Yes this could be his block?
Name:	Big Cheif IA IIA race block.jpg
Bob C.
Boss Bird Funny Car
  #57
Old 06-06-2016, 08:38 PM
I measured the deck height of our block today. 10.235". It's also nice and square +- .001. Planning to use it as-is. Working on sleeves next.
  #58
Old 06-06-2016, 08:52 PM
Tom Vaught's Avatar
Boost Engineer
Good news and will make your Race timing schedule hopefully.
Tom V.
  #59
Old 06-06-2016, 09:54 PM
smokey 1978's Avatar
smokey 1978 smokey 1978 is offline
Send a message via Yahoo to smokey 1978
how much boost can this block handle!
Albert Marquez
1965 GTO TWIN TURBO DCI RA5!
  #60
Old 06-06-2016, 10:28 PM
Robert C.'s Avatar
More then most will dare to try. Nitro boys are building a block. There is a twin turbo build going on.
Bob C.
Boss Bird Funny Car
