Old 02-02-2024, 07:34 PM
Cammer-6 Cammer-6 is offline
Default any tips on removing sport coupe(post) trim?
got it all except the 1/4 window trim
Whats the secret?
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 02-02-2024, 07:57 PM
gtospieg gtospieg is offline
I've been through this a couple of times. You need to drop the rear window inside and then remove the upper window channel to get to the screws that hold the upper piece of trim in place. Depending on the condition of the upper window channel, now might be a good time to rebuild/recreate that piece. If you would like me to explain further, drop me a PM with your # and the best time to call. Good luck.
Old 02-03-2024, 01:24 PM
wow quite the Easter egg hunt.
Im glad I didnt try and muscle it out.
only 2 of the 3 mounting tabs had screws in it,
which would explain why it was loose at bottom.
If I would have seen the part off the car it would have been obvious
thanks for the tip.
Old 02-03-2024, 07:26 PM
Not that hard once you see it...glad it worked out for you.
