Post #26 seems to be most pertinent to this thread here. I also thought this from #48 was pretty interesting: I never considered that when comparing two cams with the same amount of overlap, the one with more-aggressive ramps would have better idle/vacuum than the cam with less-aggressive ramps. "Gut feel" was that aggressive ramps give an aggressive idle - but the opposite appears to be true. That helps explains why an LS engine with roller lifters idles better than a flat-tappet SBC with similar cam specs - the roller lifters allow more aggressive ramps. And this from post #33: For years I have have heard wide lobe sep for good vacuum. Well how about properly cammed engine for the intended rpm range and if the LSA is a 107 then thats what it is. I've got several of you on here and many others with vacuum reports of 11 to 15 inches during idle. These are customers wanting street cars with pop. These are not drag cars. Many circle track sanctioning bodies have Vac rules. Some pull truck stuff also. I have learned over the years manipulating the valve events you can achieve vacuum. These cams aren't on 112 or 114 LSAs I can assure you. Both tend to illustrate that LSA is useful to a point but valve event details tell you a helluva lot more. |
engine masters show did a test with 3 different LSA cams all else same
also a show on just same cam advanced / retarded and another show on just split duration cams all else same very infomative on ICE. trends |
The Following User Says Thank You to Formulas For This Useful Post: | ||
LSA falls in with all the other aspects of the engine that determine how efficiently it behaves as an air pump at varying speeds. In this case, LSA determines how long the intake and exhaust valves are open at the same time during the transition from exhaust to intake stroke.
At high engine speeds, the exhaust is moving so quick that having both valves open at the same (narrow LSA) time allows the escaping exhaust gases to draw in more air for the intake stroke before the piston has started moving down, hence improving high-RPM cylinder filling and efficiency (ie. high-RPM horsepower). Conversely, at low RPM, the same conditions just cause a delay in the piston being able to create the necessary vacuum to draw air in, thereby hurting low-RPM cylinder filling and efficiency. In extreme cases, the piston might even be drawing exhaust back into the combustion chamber before the exhaust valve fully closes, thereby diluting the mixture. These are the reasons for a "lopey" idle. Looking at it the other way, a wide LSA means there's less overlap, so the piston's downward motion creates more vacuum in the intake manifold, thereby speeding up cylinder filling and improving efficiency. This generates more low-end torque. But as the engine speeds up, the lack of overlap means that the transition between exhaust and intake is more abrupt, the flow of air is interrupted, and cylinder filling isn't as optimal. It's more "pulse-y", if you will. That means less potential horsepower at higher RPM. Everything is a compromise. The solution is variable valve timing, which every modern engine has. But in our case, the real solution is just to pick a power band for our purposes and build for that. In general, the more vacuum a cam produces (wide LSA), the more power it will make below 5500rpm and the smoother it will idle. I like a cam with an LSA of 114. I don't much care for a lopey idle, and I don't need high-RPM horsepower on the street. |
The Following User Says Thank You to GoreMaker For This Useful Post: | ||
Question - A tighter Lsa cam is going to result in reduced fuel economy and increased emissions at idle and lower RPMs. But can one improve fuel economy and emissions at mid and higher RPMs? Last edited by ekancler; 06-22-2022 at 12:13 PM. |
The Following User Says Thank You to ekancler For This Useful Post: | ||
you should watch the engine masters results ..... to see the trends ... when they used a wide lobe sep the ONLY place it made more power was a small blip at the last 200 rpm in the run which started at 3000 yes a wide sep has a cleaner idle to 2000 ish rpm which is not captured on a dyno iam not going to argue or re'count the entire show its easy enough to find watch and understand |
There seems to be differing opinions/experiences on whether a wider Lsa, all else equal, will start to outcompete a tighter Lsa cam at the highest RPMs.
Yes, wider Lsa is more efficient and powerful at idle and very low RPMs. Yes, tighter Lsa cams outcompete in the mid-band and high RPMs due to better scavenging. But at the highest RPMs, and this holds true in articles and videos I've read/seen, sometimes the tighter Lsa cam maintains an advantage, sometimes it loses its advantage at around peak HP. What are the competing phenenoma at play here? |
Rhoads lifters have been providing variable valve timing for our older engines for decades. Combining them with high ratio rocker arms and well chosen duration/LSA for the engine CID and compression ratio and one can very quickly mimic the power of a very well chosen HR cam at much less cost..
All hydraulic lifters provide some variable valve timing based on the design (leak down rates) but for the most part those with very tight plunger to body tolerances act pretty much like solid lifters. Overlap plays a big role in engine function and it is a product of the LSA and duration of the intake/exhaust lobes. Cam companies push tight LSA for the most part. This is done more for the "bling" factor than anything else as it makes the engine less efficient at idle speed so we get "low" vacuum and some "lope" in the exhaust note. I've installed/tested a lot of camshafts in these engines. In the 455 engine really tight LSA makes for "explosive" mid-range power as it enhances what they are already very good at. Wide LSA smooths them out some and pushes peak power higher in the RPM range. What I have done and do here is to use higher compression than most, more duration, relative wide LSA and end up with engines that are user friendly with good idle quality and street manners, but still run very strong at the track. The WORST 455's I've built, worked on or tuned have been lower compression with smaller cams on tight LSA's. Can't say "turd" loud enough here and that is not a good direction to go with them......IMHO. When you get into moderate compression 455's and bigger camshafts LSA really matters a lot less as they are going to make great power either way, so it becomes more of a matter of personal choice at the point. Some folks like "menacing" idle quality and stinky exhaust, others prefer their engines to be a bit more tame at a glance. Either way it's hard to kill one off provided you have put a big enough cam in it. Here the smallest cam I'd ever use in a 455 build would be 230 @ .050" and a least 280 @ .006".............
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
Post 13 Note 2: Tight LSA vs Reversion;
Well, my exhaust study showed the need for large long Collectors to mitigate Reversion, yet ironically enable an "EGR" during cruise rpm. So i built 5" dia, 37" long Collectors that bolt onto the Header' existing Collectors. Mechanically clean, and the Reversion seems quite mitigated ( been over a decade so i'm keeping them on..). Such collector extensions time the "boost from overlap" to kick in at 3900 rpm, and supposing the 1/4 mile results indicate the long collectors do no harm. Highway cruise in OD lacks lugging. Pull-aways in any gear are possible and practical, except in OD being possible but not practical. I pull away in OD at times out of laziness to move the shifter or see how she runs. 9.00:1 with LSA per Sig. I will read/see me Sig when this post shows. Says 112! Hmmm, gonna need to review some cam cards. The 108 LSA was designated for the Spare engine.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct Last edited by Half-Inch Stud; 06-23-2022 at 08:41 AM. |
I would NOT use, recommend or even play around with super tight LSA camshafts with the ICL down in the 90's or even low 100's. I've had quite a few customers venture in that direction following magazine articles showing "amazing" dyno results from that deal. One of those experiences was recently where a customer bought some carb rebuild and tuning parts for his 454 Big Block Chevy. During the conversation I asked about the CID, compression ratio, cam specs etc. He very quickly told me that the engine was 9 to 1 compression, and cam was ground on a really tight LSA with the ICL down around 100. I remember the seat timing was also pretty short, 262 degrees @ .006".
I did my part and supplied what was needed to get the carb rebuilt and up to par. Once placed in service the phone calls started coming in, NOTHING with that engine was working well or making the grade, and no tuning efforts with the carb and distributor were making it any better. After quite a few nearly endless phone calls things went silent so I don't know what they ended up doing with it. I do know that everyone involved was pretty disappointed in it. Just a guess on my part but the cam wasn't big enough for a moderate compression 454 build right to start with, and would only get worse closing the intake really early and not much seat timing as well................
Clearly he had not enough duration.
Stan
Here is some text I have saved that may help some on LSA:
The Following 2 Users Say Thank You to johnta1 For This Useful Post: | ||
Thanks John
Not nearly enough duration for sure Stan. Keep in mind that magazine articles don't always explain to the readers that following a course of action using a 102LSA cam with the ICL at 98, for example, doesn't work for chit if you try using a cam with 50-60 degrees LESS seat timing at .050" than the one the "professional" engine builder spec'd out for his custom "max-effort" deal.
For sure targeting specific engines with those sort of cams may help win a dyno contest for the Engine Masters articles, but it's the WRONG direction to go with your tiny little street cam chosen to build "more low end torque", which are EXACTLY the words my last horribly disappointed customer told me when I asked about his engine combo and choices he made for it.......FWIW.....
The Following User Says Thank You to Cliff R For This Useful Post: | ||
i loath and despise the Scooter Borther explanation: too longk, many useless scenarios, and LCA in place of LSA.
Oh heck; Pick you idea intake lobe duration and ILC ( Intake Lobe Center ). The pick you mandatory Exhaust closing for best performance. Then I bet you can jerk the Exhaust Opening (and thus EXH Lobe duration) between 90* ATDC thru 120* ATDC and have only minor performance difference (yet a loud exhaust note for 90*ATDC) And the resulting LSA will jerk a 30 degrees spread too. So here, a few words were used to make clear my concern for LSA specing as be-all end-all. |
The Following User Says Thank You to Half-Inch Stud For This Useful Post: | ||
Please don't miss quote me. I did not said "tiny little"!!!! Even if he ran 110 octane to handle the cylinder pressure and could run full timing. He would be lucky to see peak HP at 4400 RPM. He had the wrong duration Stan
#38
the engine masters dyno show is not a show of extremes or targeting a specific winner based on any wonky parimiters to pick a winner
they "USUALLY" take a brand X engine that can be catagorized as a healthy street engine and explore different engine building myths and tecniques on cams they took an engine and ran it on the dyno just changing where the cam was installed at =ICL and examined the power curve on another episode they used same exact lobes on 3 different cams only change was lobe centers and examined dyno chart results another episode they examined camshafts main difference was single duration and split duration and examined results its all pretty usefull information if you would give it a chance they also did back to back cast iron and aluminum heads comparison same ports same chambers same company, and no you dont have to have more compression with aluminum or more timing, alum came out the winner slight edge on power and less weight i must be the only viewer but alot of what you think may not be right per test results |
The Following 2 Users Say Thank You to Formulas For This Useful Post: | ||
#39
Hence why it's best to choose a camshaft based on valve opening/closing events. LSA (aka LCA) and advance are just reference to calculating those events.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
The Following User Says Thank You to amcmike For This Useful Post: | ||
#40
I believe he was referring back to the contest series that PHR ran years ago, not the show.
