Door Jam Paint Advice
Below are some pics of my door jams, they were painted in SS maybe 20 years ago. Should I strip all this off before painting with BC/CC? Scuff and seal with epoxy primer? Leave them be? They still shine, color is good ... no problems other than the hinge area.
If they still shine good I think it depends on the level of restoration. Looks like it is pretty torn down which means everything else is going to look new. While they look good now I’m not sure they will look as good next to new paint, interior, etc. if the budget allows it I would probably paint them since it is so accessible
You've gone this far with making everything the best you can, so if you don't paint them now, you'll be kicking yourself later
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
I would be taking most of it down pretty far and prime with epoxy, then paint when body is ready. Your new paint will adhere only as good as what is underneath. Why risk new paint.
Jeez, you guys never give an answer that will make LESS work
Away with the old paint then, thanks for the advice. |
I see u r using a paint removal disc ( Roloc ? ) not sure if that's the name anyway how is it for paint removal ...im gonna be in the same process soon for paint removal too panels jambs etc...thanks for any input...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
They are the typical Angle grinder mounted fiber abrasive disks ... got them on Amazon
https://www.amazon.com/gp/product/B01B8GQ0BW Most of them are probably the same more or less. They remove paint and rust very very quickly, last a reasonable amount of time. If using on just paint, on smooth metal, they will last quite a while. They certainly remove it quickly. What does them in is snagging them on sharp edges, chews them up quick. You have to keep the rotation direction constantly in mind and if you have an edge make sure to have the rotation going off the edge, not into it .... will also try to yank the grinder out of your hands when it snags. Doesn't produce much heat just removing paint. Rust, undercoat etc will generate a bit more. I can't advise one way or the other for paint removal on the exterior of large body panels yet. But for areas like door jams, firewalls etc. they are excellent. |
Unless you’re building a show piece just paint the A pillar and leave the rest as is if it looks good to you. Fact is with doors and hinges in place I don’t see the need to paint anything just for the sake of painting something.
If it looks as good as the pics, I would put my time and $$$ elsewhere. Just my 2 cents. |
Ah. You should've asked me then. Just leave it in primer.
The Following User Says Thank You to 242177P For This Useful Post: | ||
Paint the hinge area with a jam gun in base. After cleaning and epoxy primer( tape it off). Then clean it all with wax and grease remover and clear coat it. This is easy and cheaper. You will then use round foam tape if you paint car with doors on.
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
So you are saying I can clear over the areas of SS that are in good shape? That would make things easier.
clean it well with a VOC based wax and grease remover ( not the soap stuff in a plastic bottle. I use Kleen strip wax and grease remover. I buy it at Napa. May want to lightly scuff the paint with a "WHITE" scuffy pad.. yes WHITE, they are xtra fine. Then wipe with wax and grease remover, blow off, use a tac cloth and mask up and paint the clear coat. |
Thank you Sir. That certainly give me an attractive option when the time comes.
