68 428 Engine 0.090 Over
Mutual friend called asking if I’d be interested in a 428 that he claims is .090 over bore. I haven’t seen the motor yet(been sitting in a car for 20 years) but curious how far some have taken these 428’s. I can get it pretty cheap I think, but curious if I’d be buying a parts engine if the cylinders have any rust from sitting and it needs cleaned up again. Supposedly has ram air 4 heads but I’ll believe that when I see it.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week 14, 15, 17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process Last edited by Hooter; 07-30-2020 at 07:13 PM. |
The only way to know if that block could be bored would be to have it sonic checked but I would be doubtful that it could be. I have a '65 or '66 (don't remember which off the top of my head?) 421 block that is currently .060 over and it will go .090 but will be at the margins and one hole will need to be moved .015 to the rear to do it. And that will be the last boring of that block. I had it sonic checked.
I just had a 69 4 bolt 428 block sonic checked. It is already .070 over, it needs a sleeve and I will take it to .090. On the major thrust side it ranged from .210 to .220 on the minor it ranged from .185 to .195. I have taken a few of these to a 4.210 bore. Sonic check will know for sure. I think Probird had one a 4.250.
This block was a GME casting.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
I have a 400 bored .090 over and put in a 4" crank and made it a 441. Don't remember what was left on the thrust side when it was sonic checked but it was enough.
Tim Corcoran |
Looking at it next week. Keeping my fingers crossed on the RA4 heads. He’s a money guy from years back. Anything’s possible.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week 14, 15, 17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
If they are RA4 heads there certainly worth a bunch more then the bare block assuming there usable also!
I have a '69 428 block in my race car that is .130' over. It's hard blocked have way up the water pump holes though. When I sonic checked it before boring it averaged .290 to .310 un the thrust side.
How does that thing run ? What kind of heads are on it ? I have a 67 .060 400 block been thinking about doing that.
Yes it runs just fine until I had an exhaust valve sticking now I have it apart to fix it. I has 6X heads ported out to 265 @28" of water and 9.0:1 compression. It has a pretty small cam in it and it has ps,pb,ac a Q-jet factory intake and runs a disappointing low 13's in the 1/4. I will be putting in a different cam while I have the engine out and we'll see if it improves. I expect with those heads it should easily be in the 12's. The pistons are an off the shelf SRP flat top i believe they are chevy 400 pistons.
Tim Corcoran Last edited by Tim Corcoran; 07-31-2020 at 02:24 PM. |
A little update - got to see the car today. The motor is in a 81 TA that hadn’t seen the light of day since 2000. The car cover had rotted off it and covered in dust from the storage unit it’s in. Sadly, no ram air 4 heads, but it does have 670’s. Motor turns over. Pulled a valve cover breather and has gold colored roller rockers. Torker 2. 800 Holley. Lots of good stuff. Agreed to buy for $500. Not sure what I’ll do with it, but couldn’t pass it up. Be a nice motor with some 6x heads in my Bonerville.
Sounds like a great score
Wow that’s just about giving it away great score for you.
Hooter,
Saw your name recently on the birthday announcements, belated Happy Birthday!!! Was going to post in Lobby, to see whet you were up to...now we all know!!! I hope ALL the parts are usable!!!
Thanks man. Only 1 year away from ordering off of the back of the Denny's menu(55 and over) lol.
Looking forward to seeing tera down of 428!!!
Happy B-day kid...I mean "HOOT".
If not gon'a use those 670's. Be interested in date code. The F017's on my 67 need completely gone thru. Guides, seats, valves and springs shot.
If you cant drive from gas pump to gas pump across the map, its not a street car. http://s207.photobucket.com/albums/b...hop/?start=100 |
That 428 Short sounds promising for good Block, Crank, Rods, Slugs. And all the bolt-ons sure help.
