Old 06-03-2020, 07:36 PM
pgp66's Avatar
pgp66 pgp66 is offline
Default Some Panel Questions
Hi all,
Three questions if anybody can assist me?
What size bolts and washers go through these holes on the inner wheel wells to the brace/bracket on a 66 GTO in the first 2 pics? Can somebody take some pics of your car for me from inside the wheel well please?
2nd, does the inner wheel wells sit a small amount away from the fender around the wheel arch with these mounts/bolts in the 3rd pic, so would be about a 1/2" gap due to the plastic mounts?
3rdly, does anybody have a 65-67 GTO hood without the Arrow emblem mounted so they can measure the location of the holes to be drilled in a new hood in the correct location? Some pics with dimensions on them, or a hand drawing with measurements would be great please if possible. See 4th pic.
Thanks heaps for your help and advice yet again.
ID:	541728   Click image for larger version
ID:	541729   Click image for larger version
ID:	541730   Click image for larger version
--> 1966 Pontiac Le Mans Convertible, Martinique Bronze, black top, Parchment interior, alloy Rallye 2's, M/T Sportsman ST's 235f/255r with redlines, 464 (455 .040 over), Performer RPM 87cc round port heads, Butler roller cam, Edelbrock Pro-Flo 4, Ram Air 2.5" manifolds, 67 GTO Ram Air pan, 2.5" Magnaflow, Muncie M22, 3.55 Eaton Posi. <--
Old 06-04-2020, 01:01 PM
lemans67 lemans67 is offline
I can get measurements for the emblem sometime this weekend if no one else does.
67 LeMans convertible. Tyrol blue, M22z autogear, 2.73 8.5, 455, FAST MPI fuel injection. 243/ 251 112. solid roller. SD performance ported 6x heads.
Old 06-04-2020, 01:15 PM
george kujanski's Avatar
For question 1, my '67 has 5/16-18 flange head pointy-end body bolts. For question 2, yes mine has the plastic between the outer and inner wheel well.
George
Old 06-04-2020, 04:59 PM
pgp66's Avatar
Thanks guys, appreciate that.
George can you please take a picture of the bolts from inside the wheelwell, just so I can see how big the washers are too if that's not much hassle?
Old 06-05-2020, 04:57 PM
ftwmlp's Avatar
ftwmlp ftwmlp is offline
I was hoping to find an answer about the hole locations by searching older posts on this forum. I found one from 2014 that addressed the question, but the images attached at that time are no longer available:
https://forums.maxperformanceinc.com...ht=hood+emblem
Post #3 from Mr. Jeff Hamlin was probably just what you are looking for. Mr. Hamlin is a very knowledgeable and frequent poster in this forum. If he doesn't happen to answer in this thread, might shoot him a pm
Fort Worth/Dallas TX area
1966 GTO Fontaine Blue
389 CID Carter AFB
Muncie 4 speed (orginally an automatic car)
Old 06-06-2020, 12:37 PM
Jeff Hamlin's Avatar
The bolt described to secure the inner tub to the brace/bracket are commonly referred to as body bolts,
these have the washer head bolt, not a separate washer.
5/16 x 18 x 1"-1.25" seems right. The washer is approx 7/8"-1".
The lower hole with the raised circle is for the rubber bumper/vibration block.
Old 06-06-2020, 05:59 PM
pgp66's Avatar
Thanks very much Jeff, thats very much appreciated.
Old 06-06-2020, 06:19 PM
Default Pic
Let me know if you need more info or a better pic.
Old 06-06-2020, 09:58 PM
topfuel67 topfuel67 is offline
I can post pics of the correct bolts and clips for the brackets that attach the inner fenders in pic 2 of your original post. The speed nuts are unique to this bracket. I luckily got a few for my car from a guy I met on CL that has amazing original so cal parts.
Old 06-06-2020, 10:58 PM
pgp66's Avatar
Thanks Lemans67, much appreciated for the hood pic.
topfuel67, yes please if you can post up some pics for the bolts and speednuts, that would also be great.
Old 06-07-2020, 09:52 AM
Thumbs up
Glad to assist.
FWIW; below are the offerings with hardware, available from several Parts vendors.
I just can't seem to recall where I found the rubber bumpers.
Old 06-07-2020, 04:12 PM
pgp66's Avatar
Thanks Jeff
