#221
Whatever we call it, I agree this needs to stop being called "LS7" anything. They are not LS7 lifters and LS7 lifters will not work. Using "LS7" in the name for this swap creates unnecessary confusion and I guarantee someone is going to try to use actual LS7 lifters and have a catastrophic failure.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
#222
The lifter I used was an ls7 lifter. It looks as though the external dimension are the same except the oil band, so the test I did to see how much on the lifter below the machined flats come out of the lifter bore is relevant. The cam was is a straub custom cam. I think the lobes are Howard's.
#223
The vast majority of lifters available for the roller cam sbc and iron dukes seem to use the latter ls7 type lifter. I wonder how long it will be before sealed power drop the 2148 lifter.
#224
They can make more. About as rare as salt.
#225
Did you pull the Delphi lifter that you measured out of an actual factory built LS7? Or where did it come from? Do you know the Delphi or GM part number? |
#226
Might look at Gaterman lifters how they stack up.Tom
#227
That's very interesting Tom. I've never heard of them. But that doesn't mean anything. Their design with 4 oil holes looks like a good idea. It would be interesting to see how they physically stack up to the Sealed Power HT 2148s. Curious about the price too.
#228
I found it from Mike Jones on Speedtalk.Tom
#229
So I was curious. I looked up Gaterman. Apparently they don’t retail. It says to call and speak to Bill. So I did. The roller lifter they make is retailed by Summit amongst others. A set is about $274. Bill insisted they wouldn’t work on a Pontiac. To me, their picture looks like it would work. He wouldn’t give me the dimensions of where the oil band is. Too bad. It looks like a quality unit. Summit lists it under Howard’s Cams (per Bill) as part number 91174- if anyone wants to look at this lifter online.
#230
LS lifter hype
All the hype on LS lifters so I took a look here's what I found.
The 2148 lifter will work to about 400 lobe lift as stated. I tried several hyd roller cams that I have and one of them the lifter body hits the lobe. All the postings on LS lifter no one has mentioned it so make sure you check clearance. So then the dog bone issue I made what I call a set of lifter handcuffs see pics spider will hold it down on top of lifter bore with spider. |
The Following 2 Users Say Thank You to pontbil For This Useful Post: | ||
#231
Dave
'68 Bird Vert, 455 , 6x-8, 1.5 HS, HEI, PPR TC-02-HF, TH400, 2500 Hughes, 2.56 8.2 (getting swapped for second gen with shorter gears) Fishing guide in the Washington state for Salmon, Steelhead and Sturgeon. Fish-On! |
#232
Ramp rate of lobe I have a video but I cant uploaded it
#233
Couple questions. Which cam had an interference issue? Do you think it was the profile of the lobe? And that handcuff you made. Very nice. Details? Are the slots wire EDM’d? What material did you make it from? Just curious, I have a machinist background.
#234
Ramp rate too fast
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
#236
I do think it’s important to point out that this specific setup is probably going to be limited to milder combinations. If you’re wanting to use aggressive lobes with large amounts of lobe lift, this setup probably isn’t for you.
In fact if I end up looking into this I’ll likely have a change cam myself. My HR is spec’d with comp’s XFI lobes. Although the lift is moderate, the ramp rates are about as aggressive as you can go on a HR setup. Probably partly why my valvetrain is so noisy.
The Following User Says Thank You to JLMounce For This Useful Post: | ||
#237
Nice work there Bill! Do you have more custom parts in the works?
Charles |
The Following User Says Thank You to Charles Baesch For This Useful Post: | ||
#238
Thanks for posting the pics I could not get the video to upload
#239
Milling them out on 6061 aluminum. Plan on printing a set out of nylon to try out
The Following User Says Thank You to pontbil For This Useful Post: | ||
#240
Bill,
This is AWESOME!!! I ride Harley's, so your idea is something I've been pondering since the Twin Cam's and M8's use a similar anti-rotation system. You guys RULE!! This is what I wanted: Pontiac people coming together to better our hobby for the benefit of all!
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
