NOS 9775810 upper ball joints for 64-72 GM A body
Will buy single ball joint but prefer a pair. Also looking for original upper control arms. Located in SoCal.
Robert 6d7gto@gmail.com |
Still looking.
Willing to pay up to $150/pair.
Still looking...
I thought there was 3 different ball joints 64-72....64-66 67 - 69 70-72
short medium and tall caps ... I have real nice control arms with original tight ball joints from a 67 Lemans upper bushings need replaced .... Scott |
Thanks Scott. I need just the ball joints at this time. Yes, I believe there were 3 different styles. The 1967 A bodies used the short dome style (9775810).
Still in the market for NOS upper ball joints (9775810). Will pay up to $200/pair for excellent condition (ie. no rust pits or rust stains). Thanks.
Robert 6d7gto@gmail.com P.S. Also need great condition original upper shafts. The kind with large fine thread lock nuts on the ends, not the ones with the small bolts that hold the bushings tight. |
An fyi, '64-69 upper balljoints are different than '70-72.
Ball joints always confused me.
NOS over the counter, would they be a bolt in piece or did the service department need to rivet them in. In an LS6 thread someone posted up images of 2 NOS ball joints (3848048 grp 6.164)one had smaller holes sized for rivets the other for bolts. Are the part numbers the same for the other A-bodies? In my notes I copied and pasted (not sure if correct, or just service part number) Upper Ball Joint #3963842 was ORIGINALLY used on: (these have the rivet size holes I think) 1964-72 Chevelle 1967-69 Camaro 1968-72 Nova Also used on A-F-X bodies for B-O-P too. So are the flatter ones for 70-72? and the tall for 64-69?
"Honestly the car will only be there for a few weeks, OK maybe a month at the most" |
I just chisled the originals off my 72 and they were the raised style.
Not sure about the other numbers you quoted. Replacement OEM were bolted in but can be riveted for that factory look. |
In earlier post, I mistakenly referred to the year range of the early style upper ball joints, in my March of '72 Master Parts books: 9775810....... 64-68 T/6-T/8 546174..........69-72 A,G By the 1/73 Master Parts books, the 546174 became the superseded upper ball joint for '64-68 model A body's.
6d7gto,
If you can come up with a pair of similar condition (very nice) NOS 546174 upper ball joints, I'll let go of a pair of same condition NOS 9775810 upper ball joints.
Sounds good but the cupboard is bare at the moment.
https://www.ebay.com/itm/NOS-GM-1970...?_trksid=p2385 |
NOS ball joint on Ebay
https://www.ebay.com/itm/333867119099?ul_noapp=true |
Confused about GM part numbers on upper ball joints
Only one point of printed reference I have with that # is a 11-1-69 dated Pontiac Master Parts book.
Grp 6.178. #9796840 67-68 F /6-F/8 69......F/6-F/8-T/6-T/8 -GP/8 The above applications noted, my bet is that particular tall protrusion ballpoint is a service replacement for most of the applications listed in the above master parts book listing. To make things more confusing as far as the complete original usage of the tall protrusion style ball joints... Two years ago, I examined quite a few '70-72 GrandPrixs with original riveted ball joints. Noticed both tall protrusion & a lesser protruding style. Will be checking two longtime original front suspension '69 GrandPrixs in the next few weeks.
