Old 12-22-2020, 10:57 PM
72lmsconv 72lmsconv is offline
Default 1972 conv top switch
When I push the UP/DOWN button on my conv top switch works in reverse
So when I hit the down button the top will go up into the trunk and when I hit
the UP button the top will come out of the trunk
Is it working in reverse and how do I fix it??
Old 12-22-2020, 11:18 PM
Bill Hanlon's Avatar
As you describe it I think it is working correctly.
Old 12-23-2020, 10:13 AM
I described it wrong-- when you hit the down button the top will come up from the trunk and down onto the windshield
and vice versa when you hit the up button
Old 12-23-2020, 02:20 PM
Scott Thelander's Avatar
sounds like the "red and green" ? wires need swapped in the trunk in the plug
we had a repro motor that did the same a few years back...
Old 12-23-2020, 09:00 PM
I will check in the trunk thanks
Old 12-30-2020, 01:30 AM
So I looked in the trunk to switch the wires -- but it is a molded piece and can't change it there
I am now looking at the switch under the dash to see if you can remove the wires in the back and reverse them
and they do not move--not sure if they are soldered or removable
Should I buy a new switch or does anybody know if they removable??
Old 12-30-2020, 08:25 PM
Hooray!! Its fixed, I was able to switch the wires under the dash and
it now works correctly Thanks Bill
