Old 12-30-2020, 06:37 PM
jimib's Avatar
jimib jimib is offline
Default Looking for ignition switch retaining nuts or washers
I don't if I should call them washers or nuts, but these screw on to the back of the ignition cylinder. Typically, they come with the ignition switch and I believe the intended purpose is to secure the threaded nut on the back of the ignition switch. I've been searching online but no results.
ID:	557215   Click image for larger version
1967 GTO, hard top, 400 Block, Butler Performance Build, EFI Holley Sniper, Tremec 5-Speed, Moser 373 Rear, 4 Wheel Disc Brakes
Old 12-30-2020, 09:52 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
I think I made spacer for mine as the original switch did not use nuts behind the dash to secure it. Well for 64 anyway.
I think I made it out of plastic pipe I had laying around that was the right size.
64 Lemans hardtop
4spd, buckets
