#61
Yeah, the nature of the hobby I guess....just makes a build take tooooo long. Richie Hoffman is doing a GREAT job for me...He notices EVERY detail!...Should be done soon-ish! You are correct...you can buy Chevy and Ford stuff in the Supermarket!!!
#62
Hang in there this is going to be fun. |
#63
Bruce, I try to buy the best parts for the engine......it is fun...I just can't wait anymore!!!....Thanks, Eric
#64
The guy is really on his game. People will get a fine product from his shop. Tom Vaught
#65
Thanks Tom, He IS very knowledgable, good at his trade, and HONEST....I didn't mean anything negative about FORD or CHEVY....(would love a 2013 Mustang Shelby).... Just "crying" about parts in general not fitting...I can't wait to fire my IAII up and dyno tune it!!! ERIC
#66
Richie "made" a cork gasket for the rear main cap, then we lovingly fitted, tweaked, and prepared the Canton oil pan. Richie installed the "smile" for the lower gasket timing cover/oil pan.....pan is now installed. ONWARD......we had to trim the sides of the valley pan a bit, and put a "chamfer'' on the bottom of the intake manifold so the vp wouldn't keep the manifold from seating properly...OK! pushrods and rocker arms next!.... ......then the blower and carbs.....Eric
#67
Investment tip: Buy stock in "Right Stuff" !
#68
Rocker arms and stud girdles are on! clooooooser! Will try to post some pics on Sunday...IF the Christmas tree is up by then.
#69
Vortech w/ geardrive
Well will be ordering my Vortech and mounting system this week. Hope to see it for X-mas. Santa being really good to me this year!!!!!!!!!! catching up to you Eric on Progress.
#70
Bryan, We're getting there...this week: how to get my headers to fit. They just barely touch the sides of the block.....I am thinking of buying another set of 3/8" inch flanges, and "double flanging"....Why should I NOT cut the header flange into seperate ones...seems like it would make fitment easy (as in cut out the metal between the exhaust ports).....gentlemen, feel free to chime in! Thanks, Eric
#71
cutting spaces
I got my headers cut. With no leaking issues. Makes them easier going in and out. my front and rear tubes are removable also. Makes it easy if needed to work on starter.
#72
Thanks fellas, I 'm gonna call All Pontiac today and order a set of flanges to "pad" the headers away from the block. Eric
#74
Got some engine work done at Richie's today....we need to move the upper blower pulley forward a bit (.715).....here are a few pics!
#75
Got the blower installed, AND THE HEADER PROBLEM figured out!!!!! The double flange system worked like a charm!! Some pics.... These are the OBX round port headers, with an extra 3/8" flange added to pad them out and down away from the freeze plugs/block......
#76
You are a braver man than me...that is a LOT of leverage and weight hanging off the end of that crank snout.
#77
looks nice
that sure is alot of belt Hope you dont get any belt slap without a tensioner on the return side.
#78
Belts too long Eric for that center line and those pulleys. Any kind of drive on the blower at all and that universal tensioner will not hold, plus you're losing a bunch of tooth engagement on the top pulley. Really it might not hold under driven - I can't be sure, I've never had one cranked all the way up like that.
The secret to happiness is not getting what you want but rather, wanting what you have. |
#79
17" center to center -crank hub to blower drive. BDS agrees on the idler angle and is sending me a 3" shorter belt. I gotta say, BDS has excellent product support...always find an answer...Craig , Norma, Herman....THANK YOU !!! Eric
#80
Good deal
