Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
#101
Between the frame and chassis mount.
#102
Why do you need a spacer in between the frame & frame mount. What does this cure?? Why do you need to space the engine that way. What problems is the taking care of, or what is the engine doing that makes you need the spacer???
#103
These are used to compensate for frame sag
After about a hundred thousand miles (or more) on our old frames, they start to droop in the center.
As the frame droops, the center comes down and the ends rise up. The fan shroud rises along with the radiator support and the fan either gets very close to or hits the bottom of the shroud. Putting the spacers in, give you extra clearance for the fan, placing it back in the center of the shroud opening. This CAN allow you to use a larger diameter blade and cool more efficiently. |
#104
i do not have that issue with the fan but my headers are on my frame will raising the motor throw anything else off
#105
Just put hardened washers between your block & engine mount
#106
I could use a set..
#108
#109
Are these for all chassis types? Do they fit 1st gen birds?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
#110
Sorry for the tardy reply... these only work on 'A' bodies with all engine sizes except 455 (the 455 has larger motor mounts and frame brackets...
#111
Just sold our 75th set. Now I know there are more Pontiacs needing these plates... Where are you..??? LOL..!
#112
They seem like a really good simple fix but I as well as a lot of others most likely have 455 engines and you say they don't work with them. i would definitely be interested if they were for my engine though.
#113
we did not design the plate to fit the 455 bracket just because I did not have a 455 in my GTO. Maybe that's something we can look into...
#114
Hmmm, I have a 455 in my 69 Lemans and they worked for me.
#115
You probably did not change out the original brackets & motor mounts to the 455 ones, right..? They are both much larger and need to use a longer mounting bolt.
#116
I used mine on a 455 as well. But my 455 had been in there already for over 25 years on the 326 motor mounts. I believe the factory 455 installations are the ones with a longer mount ('70-'72)
#117
Yes, it sits on the original frame brackets.
#118
I have a set of 350 motor mounts as I am in the process of swapping in a 455 to my Lemans. I will have to check and see if it will work to put the 350 mounts in or if it is better to have the 455 mounts in. I really like the idea of adding a little extra clearance for my headers, hopefully the 350 mounts will work so I can pick up a set. Thanks for letting me know.
#119
This is the engine crossmember in my '66 Tempest Custom wagon when I pulled the engine to detail the compartment and install stainless brake lines about 2 1/2 years ago and I installed the spacers under my frame brackets while it was out. Actual "455" engine frame brackets have a little bit longer "loop" for the bolt to go through from the mount.
