Hi all. I have a late 1990s Jeep Grand Cherokee steering box in my '66 GTO. I purchased it as a remanufactured Lares unit from Rock Auto. I enjoy the quick ratio, but find it to be very dead on-center when driving down the road. So today I removed it from the car to see if it needed to be adjusted.
I loosened the preload adjuster nut on the pitman shaft, then adjusted the worm bearing to where it felt appropriate. From there, I re-tightened the pitman shaft preload adjuster nut so that it was just tight enough to remove any slop but not cause bind. The problem is, when I adjust it so there is no slop with the pitman arm pointed straight ahead, there is slop when I move the pitmarn arm to an off-center position. If I adjust it so there is no slop when the pitman arm is off-center, it then becomes too tight to move the pitman arm back to the center position. Am I doing something wrong here, or is my steering box defective in some way? See video for demonstration: https://youtu.be/5w9zyQcr2C8?si=ecw_Q1z9tjZF6WLA
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
There is a sequence in the preload adjustment. The worm gear thrust bearing preload is measured 1st with the adjuster plug loose (Drag). The adjuster plug is then tightened to get the preload spec and the the locking nut is torqued down. This step can throw the thrust bearing preload off so you need to be able to hold the adjuster plug still.
The rack and recirculating ball preload is next. A tool is used to hold the recirculating balls withing the rack. The assembly is then slid into the steering box as you turn the worm. If the correct recirculating ball size is selected, only a slight increase is drag will be measured. If there is no increase, choose the next larger size. I install the pitman shaft at this step to prevent the rack from rotating. Install the pitman shaft cover and perform the final preload steps through the center high point. I attached a worksheet I use to adjust the preloads. The shop manual steering section 9 goes into more detail. Special beam torque wrenches are used to measure these tiny preloads and you can get by with a digital Mitutoyo micrometer to measure the recirculating ball diameters. GM recirculating ball inventory is pretty much depleted. eBay, Ali-Express, etc has metric versions that can cheaply make a select kit. I don't know the quality but I was considering trying them for future projects. I think they are used for bicycle rotating assemblies. In your video, the amount of play doen't appear excessive off center. The center high point is the only spot where you get the greatest preload. |
I haven't disassembled the box and I don't intend to, so I'll just have to assume the correct recirculating ball size is present inside. Kinda interesting that the amount of play shown in the video when the pitman arm is off-center is not considered excessive. I haven't spent enough time around these boxes to know what's normal and what isn't. Without knowing any better, I'd have assumed that there should be play at any point along the arc. Seems that isn't the case?
Thread Tools | |
Display Modes | |
