Old 06-01-2010, 11:32 AM
oldtimebaseballfan oldtimebaseballfan is offline
Default $9,999.,1967 GTO 400 HO 4 Spd PHS
1967 Hardtop, 400 HO, 4 spd, buckets, console, Tyrol Blue, Parchment interior, PHS documents. No vinyl top.
2 engines with this GTO. The HO engine which is not in the car and a 69 400 which is in the car.
The body is pretty good for the most part. The specific bad items are around the rear window bottom and part of the rockers.
The floors and trunk are solid.
$9,900.
Here is a link to more pictures.
http://s76.photobucket.com/albums/j2...dies/67%20GTO/
Tim
1967 GTO PHS Docs, HO 4 speed, Tyrol Blue with Parchment Bucket seat interior
1971 GTO Convertible PHS Docs, 4 speed, Castillian Bronze with black top & interior
GTOAA #14364
Old 06-01-2010, 12:47 PM
Cheesehead's Avatar
Cheesehead Cheesehead is offline
Are all items pictured on photobucket for sale? I am interested in the Hurst shifter, PM me if it is for sale. Thanks
Old 06-01-2010, 02:08 PM
The parts go with the car.
Tim
GTOAA #14364
Old 06-01-2010, 09:07 PM
theYman's Avatar
theYman theYman is offline
pm'd you.
The thick CLOUD of tire smoke ,the SMELL of burning rubber,and the CHEER of the crowd ....PRICELESS.
$90.00 fine for an awesome burn-out,worth every penny...
http://www.youtube.com/watch?v=iI7beXh7xW8
Old 06-01-2010, 09:39 PM
Got it. Sent you a PM.
Tim
GTOAA #14364
Old 06-02-2010, 07:03 AM
The Boss's Avatar
The Boss The Boss is offline
Looks like a great deal - does it run and drive as it sits?
Somebody needs to buy this car!
And go racin' in the street.
Old 06-02-2010, 09:36 AM
It does run but it's been sitting so I would want to do some maintenance before I put it on the road.
Tim
GTOAA #14364
Old 06-03-2010, 12:33 PM
bigpop bigpop is offline
Is it the original HO engine? Larry B.
Mr. President, you can't say Dallas doesn't love you "
Old 06-03-2010, 08:41 PM
As you probably know, in 1967 the VIN is not stamped on many of the engines. Since this is the engine that came with the car, it may be original but not positive. Unless there is another way to verify?
Tim
GTOAA #14364
Old 06-03-2010, 09:07 PM
67&05gto 67&05gto is offline
The early 67 GTOs included an engine unit number that is under the letter code on the front of the block, that same number is listed on the PHS billing history. Mid year in 67 is when they started adding the VIN to the front of the block at the same time they relocated the casting number from the dist. pad to behind the #8 cylinder.
Old 06-04-2010, 05:00 PM
I read your information and looked at the picture of my engine front and I don't see any numbers. I am not sure what this means.
Tim
GTOAA #14364
Old 06-04-2010, 07:55 PM
Tim,
Your car is really a good price being a documented HO car and I am not trying to discredit your ad, here are 4 of your pictures where I circled information to help you identify whether the motor is original to the car.
The first picture shows the build date of your car being the first week of April, 1967;
The second picture is the build date for the heads which is October or November 03, 1966, (I believe (I) was not used in 67 date codes) these are early production heads, I didn't see a date code for the block which should be on the distributor pad with the 6133 casting number.
The third picture shows the engine unit number stamped on the block for early 67 engines.
The forth pictures shows the engine unit number which should match the number stamped on the block and the invoice date matches the data plate build date;
Good luck with the sale!
Old 06-04-2010, 08:23 PM
I am aware of the dates on the car and the engine. That is why I have not said the engine is the original engine in this car. If someone wants a PHS documented 67 GTO with the HO engine option, this car meets that criteria. The ad does not state original engine. It states PHS documents showing this is an HO car.
If people want to look at the good points they will find this to be a good deal:
67 GTO Hardtop
400 HO option
4 speed
Buckets
Console
Tyrol Blue
Parchment interior
The interior is decent,
the body is mostly solid except where stated in the ad,
the engine that is in the car runs,
there is an HO engine that comes with the car,
there are extra parts that come with the car.
All this for $9,999.
Tim
GTOAA #14364
Old 06-05-2010, 07:45 PM
chief455's Avatar
chief455 chief455 is offline
Wink
^ unsure
^ sure
I think 67&05gto was trying to help what seemed like confusion on how to identify the block.. But since you are aware,
Just saying the HO engine is not original to the car but the correct year would have been a clear approach...
great optioned car at great price - bump for a GTO sale guys!
Old 06-26-2010, 06:34 AM
Trans-Formula II's Avatar
Trans-Formula II Trans-Formula II is offline
Red face
I really wish I (we) was looking at this time for a car, I would love to own it.
