Thoughts on engine analyzer dyno chart.
This is projected dyno . I know numbers can be off, but based on this chart, what can I expect for performance- like how it will respond, idle quality in a 467, 4.25 stroke. This is for a projected 9.8:1 cr unported heads and cam with ultradyne lobes H5/H15 on a 115 LSA, advance 7 or 8 degrees. 288/296 and 231/239 at .050
I think you are grossly overestimating the cfm of the heads.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
The math for cfm needs from hp numbers is as such below.
454 hp\8 = 56.75 hp per cylinder. 56.75 / .43= 131.97 which is air flow @ 10" test depression. To get the needed air flow at 28"test pressure X by 1.67 131.97 X 1.67= 220.3 cfm. Stock big valve iron D port heads flow no more then 208 cfm at best at a 28" depression , and this 208 cfm comes in way up at .650" lift! 208 cfm will make 54 hp per cylinder for a hp number of 432 hp, and this 432 hp is not going to happen on a street motor with under 11 to 1 compression !
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 11-27-2019 at 07:22 AM. |
I made 450 dyno hp with 220 cfm 96 d-ports. However the flow at lift was 210. 9.25-1 463, 240/246 hft. Made 532 ft lbs at 3300.
Propelled a 3720lb ventura to 11.98 @ 109.5. It ran that number through the exhaust with the air cleaner on. At the time it had Redneck converter that flashed to 3900. 60 ft was 1.61x. I later took the aircleaner off and it would run 12.0's consistently. Then I put in a jum hand converter but never ran it at the track. Last edited by ponjohn; 11-27-2019 at 12:38 PM. |
I can comment on the idle quality.
Once the carb and distributor are tuned properly, With a 231-239 @ .050 in a 467, and spread out on a LSA of 115, then installed 7 or 8 degrees advanced, It's going to idle nearly smooth with only a very slight hint of something going on, and likely produce 12-14 inches of vacuum if the compression ratio stays close to 10:1 Should be a very docile camshaft in an engine that size. As an example, here's a 239/243 @ .050 on a tighter 112 LSA and installed at 106.25 ICL, in a 9.98:1 compression 462 CI engine. Even this cam idles pretty docile with a very slight lope, and only drops 150 rpm in and out of gear, and is making 12 inches of vacuum. https://youtu.be/AOqwz3QlO5k |
I made a mistake in my post. Dyno simulation was actually ran with standard KRE heads and their advertised flow.
4.250 stroke unported KRE heads Performer RPM intake w/ Q-jet 231 degree hyd flat tappet cam 502 hp at 5300 http://www.pontiacstreetperformance....d455MikeG.html .
