Old 12-28-2020, 12:46 PM
Vckline313 Vckline313 is offline
Default Can someone identify things for me
Looking at info on these heads and manifolds. Manifolds I assume are regular factory ones. Curious on the heads which were supposed to be "worked" these pics were sent to me from previous builder from when the motor was assembled probably 10 years ago.
Sent from my SM-N960U using Tapatalk
Old 12-28-2020, 01:04 PM
Looks like 16 D port heads a "72"cc chamber head. Intake is a later 75-79 EGR manifold. Exhaust manifolds RA/HO for D ports
Old 12-28-2020, 01:06 PM
LOOKS LIKE A STOCK REBUILD ON A SET OF LOW PERFORMANCE HEADS.
The ports do not look like they have had even a port match on them
The Heads have press in rocker studs and bolts to hold the guide plates to the heads
Stock Oil Shields and stock diameter springs assumed
Engine does have Ram Air D-Port exhaust manifolds.
Picture does not show the casting number on the 2 center exhaust ports well.
Not sure where the "Worked" comes in. Looks like a stock rebuild engine to me with some bolt on stock parts.
Intake is a later model EGR intake and the heads are not later "EGR Heads" Can't read casting numbers from photo.
Old 12-28-2020, 01:19 PM
Those pictures are not the best for doing detective work from, but I take a shot at it!
The heads are 1969 casting number 16, and since your pictures show pressed in rocker studs they started life as the 2 bbl small valve heads, can't say if there where remachined for the standard 4 bbl size valves which is common, and since that are/ where 2 bbl heads they are NOT the high compression 72 cc versions.
The intake manifold is a stock smog unit and not the best in terms of max HP.
The Rods are aftermarket H beam type and should be good for atleast 600 hp.
The block looks to be a 400 that may have been assembled wrong because of the main cap with with the windage tray mounting pads in on number 3 , when the number 2 and 4 main cap should have the mounting pads
The other possiblity is that this a a late 400 block when they did away with the windage tray which means only the top of the number
2 main cap has mountings pads which where used to mount the dip stick tube bracket, a job that the windage tray used to do!
It hard to be sure, but the oil pump looks like the needed 60 lb pump, but the braising job to hold the pick up on is done like crap and is excessive!
The motor has ram air type Exh Manifolds.
The center of the lifter valley above the Cam can at times tell you the cid of the motor, as in 35 being a 350 block, 0O is a 400, 28 would be a 428 and 55 would be a 455.
Note that heads with pressed in studs should not be used with lifts over .450" ( especially with stock springs) and with poly locks for valve adjustments!
Old 12-28-2020, 01:28 PM
Sounds like I got better stuff than I thought lol especially with the manifolds
Old 12-28-2020, 01:34 PM
Formulas Formulas is offline
Square cheeks on center or crank 455? I totally forget what a 400 crankshaft is like there.
Wouldn't #16 heads have screw in studs?
Old 12-28-2020, 01:47 PM
My guess is it’s a 428 360 hp engine 16 heads with press in studs and the block has the lug on rear so we know it’s not a 400 or 350. The date codes and block stamping would give you the answer.
Old 12-28-2020, 01:56 PM
Probably 1970 small valve 400 heads that had press in studs, I’m thinking 80cc chambers. Not at all a bad head, the ports are essentially the same as the big valve 16 heads. The press in studs kind of limit the ability to run cams with higher lifts and spring pressure but will suffice for milder lower lift street cams if not pushed too hard.
The iron EGR intake is a fine street performance intake.
The Ram Air / HO exhaust manifolds are a nice upgrade from the standard log-type manifolds.
Old 12-28-2020, 02:01 PM
Looking at the picture of the block casting number last numbers look like ***428 I think, it’s hard to see but that would make it a 455. Can anyone else see that picture any better?
Old 12-28-2020, 02:06 PM
If they are 1969 428 16 heads they are small valve heads that’s why you need date codes.
Old 12-28-2020, 02:29 PM
It's not a 428 crankshaft due to the square center cheeks, 428' are round there
That's an easy way to identify a larger journal 428/455 crank without measurements or part number
Old 12-28-2020, 02:32 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Block has the pyramid on it so, it`s not a 400. Looks like a 455. `69 360 hp 428`s had 46 heads, so they are most prolly `70 16 400 2bbl heads.
Old 12-28-2020, 03:05 PM
The other thing I noticed is it’s not drilled for four bolt main. The only other 3.25 block I have seen personally not drilled was a 72 455 block.
Old 12-28-2020, 03:36 PM
johnta1 johnta1 is online now
The block is a 455 with casting #485428, the crank is a 455 also with the squared cheek.
The head can be ID if you tell us what the 2 digits are on the center exhaust ports. Possibly a #11 or even #16. (or couple others)
Not sure why they used the 2 bbl heads or small valve heads.
Not that hard to find some better heads. Especially with the exhaust manifolds used. (worth more than the heads)
On the front of the block, passenger side below where the head mounts will be some numbers and letters. Tell us what they are and it can be determined closer to what the block is.
Old 12-28-2020, 03:45 PM
I looked at the drivers head and I see 5 2 stamped in the middle, but can't find anything other than a 5c code online
Old 12-28-2020, 03:48 PM
Hell maybe it says 62 idk lol my eyes aren't the best at competing with rust and old paint
Old 12-28-2020, 03:52 PM
Found this casting number
Old 12-28-2020, 04:00 PM
PunchT37's Avatar
The more I look at it, it seems like a 455 with 2 different heads on it. A 15 and a 62?
Old 12-28-2020, 04:02 PM
I'll try to get a Pic of pass side head. I was driving the car and it's too hot to stick my hand down there
Old 12-28-2020, 05:09 PM
llwta76 llwta76 is offline
Yep . I agree. ^ 1970 small valve big car 455 with a #15 and #62 head. Those need to come off. Totally different heads . Larry
