OHC-6 TECH Over Head Cam projects, questions and advice.
Old 12-18-2012, 08:59 PM
sledge hammer's Avatar
sledge hammer sledge hammer is offline
Default valves
Took a closer look at the head today and it looks like I will be needing replacement valves.
Does anyone have replacement valves for the 1969 4-bbl head that they would like to sell?
or..........
Does anyone know of a supplier that these valves can be purchased from?
Thanks allot for you help! Dave
Old 12-18-2012, 09:53 PM
Cammer-6 Cammer-6 is offline
69 used 2 different valves early 30 deg vs later 45 deg
you can sub others if you do a 3 angle valve job
68 4 bbl is same length and very close to 66-7 1 bbl
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 12-18-2012, 10:32 PM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
When buying valves just don't look at valve stem length, be aware of the keeper location. When someone just sticks a Chevy valve in the OHC engine because the length and diameter is the same, they don't take into account the stem above the retainer. My OHC had one that was off. The valves pictured are all the same length, but you can see the one in the middle has the keeper too high up and the cam follower rubbed on the retainer.
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 12-18-2012, 11:30 PM
and that actually makes installed height of spring too high also
Old 12-19-2012, 12:38 AM
Thanks for the good info guys!
Looks like I need 2 intake valves, 45 degree seat, I measured them at 4.905 length.
And I need 6 exhaust valves, 45 degree seat (I think all Pontiac exhaust v/v's are 45) at 4.893 length.
Does anyone have any spares?
Old 12-19-2012, 12:50 PM
I 'might' but I won't know until I get back home around New Years. My engine used 45* valves and I replaced one so I may not have a full set of exhaust valves and I have to check the seat angle on the intakes I have as I did not look at them closely since I decided not to replace them.
Not sure what egge's has instock and I think Ebay had a few.
Old 12-19-2012, 02:38 PM
Thanks Silver, Hope you have a terrific Christmas! Dave
